Rewiring VATs?
Car: 1992 Camaro RS
Rewiring VATs?
I was wiring up a button to push start my car and accidentally snipped the VATs wire (the two white ones)... Now my car won't start, when you turn the key to the on position nothing happens no warning lights or anything. Since I have the starter bypassed and everything with the button I can crank the engine but it wont turn over. I know there are ways to bypass VATs with resistors but after reading up on it I think I would have an issue doing that since the only key I have for the car has the chip on it which combined with the resistor would cause it not to start either. My question is is this VATs that's keeping my warning lights from coming on and my car from starting? Also is there anyway to rewire the VATs from the wires I snipped? It's not the battery or anything else because before I snipped the wire I tested everything and it would turn over but after the VATs wire nothing...
Transmission: 5-speed/T-5
Re: Rewiring VATs?
Yes, it's the VATS that is not allowing your care to run.
Just reconnect the wires, and the resistor in the key will then again be read and allow the car to run.
FYI, when the resistor bypass is performed, the key cylinder gets removed from the equation. The resistor is connected between the two white wires and the key cylinder disconnected from the circuit.
Car: 1992 Camaro RS
Re: Rewiring VATs?
Alright thanks for the reply, it turns out I didn't have true connection for the 12Vs that power the dash... Now back to VATs.. I notice there are two wire a purple and a white one coming out of the clip that the two white ones connect to. If I snip the purple and white from the clip and eliminate the clip in whole does it matter which wire is connected to whatever white wire? Sounds a little dumb but does the purple wire need a specific white wire?
Re: Rewiring VATs?
No, you can connect in either polarity (for lack of a better description).
Earlier cars only had white wires on both the car side and the column side, not sure why they changed that in later cars, but the same applies.
Car: 1992 Camaro RS
Re: Rewiring VATs?
Alright well I get power to my dash and all the warning lights come on like it normally did but now it won't turn over? It cranks and cranks but won't turn over, when I turn my key to start the car the temperature gauge maxes out and nothing happens. Once you let off the key the temperature gauge resets.
Re: Rewiring VATs?
Yeah, that's called a gauge test, similar to bulb test on non gauge package cars.
Have you reconnected the VATS wires yet?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1992 Camaro RS
Re: Rewiring VATs?
Also here's a video to show that you actually helped me quite a bit!
http://www.youtube.com/watch?v=uwSit...ature=youtu.be
Haha thanks for the correction, I'll definitely start correcting people when they say that! (and myself...)
Car: 82 Z28
Transmission: T400
Re: Rewiring VATs?
Just helps if everyone is using the same terminological when describing a problem .
Too often confusion on here arises because one poster's description of a problem does not align with how most others would describe it
