My horns smell funny
Old Jun 24, 2013 | 01:23 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Now that I've got your attention
I have a grant steering wheel that I put in my car five years ago. The horn worked fine until yesterday which is when I took off the wheel (very easy, just five visible bolts) for ease in removing my cluster to replace burned out bulbs.
After the wheel was back on, I blew the 20 amp accessory fuse seven times in a row, got sparking from my fuse box and even had the replacement fuse start to melt on one occasion. I believed it to be a grounding problem - related to the wheel - and I was right; the horn button install bracket had been installed backwards by me. The accessory fuse now works again, but, the horns do not.
* I pulled and cleaned the relay and it works.
* Strong clicking is heard when the wires are attached to the button and it is pushed.
* I have 2 stock horns and both connectors were sprayed and the terminals cleaned: still nothing!
Here's the funny part: when I put both horns close to my face, hoping to see some visible defect, I was hit in the nostrils with a strong burning/burnt smell (therein the title 'my horns smell funny').
So, is this possible? Can you burn out a horn (or two)? I need this advice before I drop 50 bucks on two replacements. Thanks in advance!
Old Jun 24, 2013 | 02:37 PM
project89's Avatar
Re: My horns smell funny
im pretty sure u can burn up a horn, head over to napa/advance/autozone whatever u have local and just pick up one of those cheap 8$ horns out of the help section hook ity up and see if it works . if it does then u know u need new horns
Old Jun 24, 2013 | 06:50 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Any burnt smell coming from some thing electical is never a good thing. Usually that smell means that electrical device will never work again.
Old Jun 25, 2013 | 01:23 PM
majobis's Avatar
Axle/Gears: G92
Is there a way to take the horns apart to see if there is anything on the inside that could be fried?
Old Jun 25, 2013 | 02:42 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Off topic but the title of this thread reminds me of when Triumph the Insult Comic Dog calls the STD Hotline.....
Old Jun 25, 2013 | 02:43 PM
project89's Avatar
no
Veaceonee
Sep 29, 2016 08:15 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
Glowsock
Sep 11, 2015 11:09 PM
