Tachometer distributor connection
Car: 1992 Camaro RS
Engine: 5.0L TPI
Transmission: 5-speed
My tachometer has been off by about 1000-1500 rpm since I replaced it about a year ago. I heard that there are two connections for the tach on the back of the distributor and you have to chose the right one. Can anyone else verify this before I dig into my engine bay, and if it is true can anyone tell me what each connection is for?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tachometer distributor connection
you might want to state what year your car is and engine, Just a guess this is a 92 maybe tbi or tpi it is the white wire on the ignition coil.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Yet another reason why I created the following thread:
https://www.thirdgen.org/forums/tech...formation.html
Car: 1992 Camaro RS
Engine: 5.0L TPI
I'm sorry I don't know why I didn't put that in my post. It's a 1992 TPI. I read that the error in reading may be a problem with the capacitor or resistors on the circuit board, I just want to make sure its not something simpler before I tear into the gauge cluster.
Engine: Lb9
Transmission: M20
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
