high performance alternator
Old Jul 11, 2013 | 05:38 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Who makes a 140 amp alternator for a 1983 305v8 CFI trans am?
Old Jul 11, 2013 | 06:27 AM
82tarecaro's Avatar
Re: high performance alternator
I am pretty sure Powermaster makes a 12SI alternator that fits our cars. Chances are your car has the 15SI alternator, but there aren't too many options besides a stock rebuild for that alternator. If you upgrade to 140 amp you are going to have to install heavier gauge wiring to the alternator charging circuit.
Old Jul 11, 2013 | 07:22 AM
KITT1983's Avatar
i installed a innovative wiring 1/0 heavy gauge battery wiring harness several years ago. i now have brighter dashlights and headlights to boot.
Old Jul 11, 2013 | 08:35 AM
82tarecaro's Avatar
Are you planning on installing something that needs the extra amps? Your stock alternator should be 85 amps.
Old Jul 11, 2013 | 10:49 AM
KITT1983's Avatar
Yep
Old Jul 11, 2013 | 06:45 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
I know a guy who used to work there. They are supposed to make good stuff
http://www.mechman.com/
Old Jul 12, 2013 | 05:55 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
an early style(86-93)CS144 is a near bolt in in place of a 15/17 Si-early cs144 is usually 108a and a big advantage is the cs144 has an updated,more powerful regulator for steadier output at low RPM.The later style cs144 has a slightly different casing but will probably fit in place of a 15si with no modifications.A 140a version is offered with the later cs144.
Old Jul 14, 2013 | 05:05 AM
KITT1983's Avatar
I found a local guy who built me a custom 140 amp alternator from a 1994 Buick roadmaster with 1 year warranty. Bolted up on the stock location with no problems. I only had to modify the electrical connector.
Old Jul 14, 2013 | 11:14 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
sounds like you got a late style cs144-any improvement in low RPM voltage output noticed so far?
Old Jul 14, 2013 | 01:28 PM
KITT1983's Avatar
Yeah a little more power out of the cfi, the a/c blows colder at idle in Boston. Brighter headlights. under all loads it does not go under 14 volts .
Hotrodboba400
Dec 10, 2019 07:07 PM
Linson
Sep 21, 2015 01:08 PM
scottmoyer
Sep 7, 2015 07:06 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
