vats problem
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: vats problem
It is possible (but rare ) for one part to fail and the other to be working.
If you have a VATS fault on the fuel component then you should have a code 46 showing.
If you don't have a VATS code up , then the ECM is correctly getting the fuel enable signal from the VATS module
and the lack of injectors is from something else.
Checked the injector fuses , checked injector wiring for open and shorts?
A bad ICM in the dist ( tells the ECM the engine is rotating so it will pulse the injectors ) is a common fault
Car: 1991 camaro rs t-top custom paint
Engine: factory 305 v8
Transmission: Standard factory tranny
Axle/Gears: standard factory axle's and gears
Re: vats problem
or you can remove the VATS and be done with it forever, I got a new PROM from Tuned Performance on here and im going to be hooking it up today or tomorrow
Car: 1992 Z28
Engine: 5.7L TPI
Re: vats problem
Not to hijack the thread or anything, but I'm having the same issue. It will crank, but I'm getting no fuel. I've checked the wiring and everything is good. I'm getting the code 46 from the ECM. I bought the Hawks Vats override module but it didn't work either. I tried both the 50hz (standard) and 30hz (it said some from 90-93 used that) signals with no luck. I'm at a loss of what to try next.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: vats problem
Your profile doesn't state what year your car is if its tbi or tpi just to verify the ecm pin location of the vats signal. Most modules have a accessory power, ground and the choice of modulated signals use the 30hz at 50-60 %.
Car: 1992 Z28
Engine: 5.7L TPI
Re: vats problem
It's a 92 with TPI. Right now I have the 30hz wire hooked up to the dark blue wire that goes to pin F10. I'm looking at an old Chilton's manual and that wire is showing coming from the pass-key decoder module to the ecm. I have it hooked up to ground and an accessory power properly, and the LED is turning on with the key in the on position as it should.
Engine: Lb9
Transmission: M20
Re: vats problem
Thats wired correctly for the 1227730, have you bypassed the starter enable relay ?
Engine: Lb9
Transmission: M20
Re: vats problem
Correct, The only other thing I can think of to check the output of the hz modulator if your volt ohm meter has a hz setting you can see what its putting out. If its not putting out the proper frequency Im not sure what there return policy is. On tpi, and 3.1L until the end of the month I will reprogram out the vats for $30 retun shipping with a tracking number.
https://www.thirdgen.org/forums/clas...-infinity.html
Car: 1992 Z28
Engine: 5.7L TPI
Re: vats problem
Mine can only check voltage and resistance, but I'll try to get my hands on one that can to test it. Sounds good. If I can't get this thing working I'll let you know. I appreciate the help.
Engine: Lb9
Transmission: M20
Re: vats problem
Np, just back probe the f10 cavity with a paper clip and make sure your signal splice is good..
GeneralIesrussi
Sep 3, 2015 03:23 AM
