2nd Fuse box?
Old Oct 4, 2013 | 01:21 AM
jrmartino78's Avatar
Car: 88 Firebird Formula
Engine: 350 TBI
2nd Fuse box?
OK so here it is...
Right side of steering wheel. I know the silver relay is the turn signals and obviously pwr seat but what are the other missing fuses, the white thing and the blue thing? This is in the dash of an 89 Pontiac GTA.
Old Oct 4, 2013 | 07:48 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: 2nd Fuse box?
i believe its called the convenience center, if your radio is still wired up properly its not gonna work without the Arc fuse,and Vats needs to have a fuse if you haven't bypassed it
Old Oct 4, 2013 | 09:52 AM
Engine: 350 TBI
Re: 2nd Fuse box?
The fuse spots are all dummy slots with nothing on the other side. My radio and everything else are working with no problems.
Old Oct 12, 2013 | 02:01 PM
DirtySpleen's Avatar
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
Re: 2nd Fuse box?
What is that little tiny switch to? if this is under the steering wheel, my car has the same thing and I have not the slightest clue what its for.
Old Oct 12, 2013 | 03:24 PM
Engine: 350 TBI
Re: 2nd Fuse box?
The silver toggle switch? That's on the side of my center console and I put that in for my knight rider scanner bar. If you have a toggle switch like that then it's something someone installed themselves.
Old Oct 12, 2013 | 05:38 PM
Re: 2nd Fuse box?
Blue thing is the security "chime".
Old Oct 12, 2013 | 06:15 PM
Engine: 350 TBI
Re: 2nd Fuse box?
Like the "door ajar" or "keys in ignition" dummy buzzer? When is it supposed to sound because I never hear anything?
Old Oct 13, 2013 | 08:53 AM
Re: 2nd Fuse box?
When you open the door and the key is in the ignition; or when the key is off, headlights on, and you open the door
Maybe it's broke?
AmorgetRS
Sep 28, 2015 09:33 PM
Dragonsys
Sep 25, 2015 03:51 PM
Tweeks25
Sep 17, 2015 08:04 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
