Fog lights dont work
Old Oct 6, 2013 | 09:44 AM
botch1's Avatar
Car: 1990 Iroc Z Red Vert
Axle/Gears: Stock
Fog light bulbs were both burned out. Replaced with new bulbs and still dont work. Small light on the fog switch does not come on when you push the switch to the on position. Any help to fix this would be great. The car is a 1988 Iroc Z. THANKS JIM
Old Oct 6, 2013 | 09:55 AM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: Fog lights dont work
Turn on headlights, then flip switch.
Old Oct 6, 2013 | 08:20 PM
botch1's Avatar
Axle/Gears: Stock
I forgot to mention that I turned the headlights on first then flipped the fog light switch. Fog lights still dont work. JIM
Old Oct 7, 2013 | 11:25 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
there is a relay, i would pull it out and test the pin with the red/white wire attached. and it says the red white from there should be there from always hot fusible link G
Old Oct 7, 2013 | 01:34 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Which relay is it? I'm having the same problem with new bulbs and the lights not working.
Old Oct 7, 2013 | 04:17 PM
botch1's Avatar
Axle/Gears: Stock
Fog lights working now. Forgot that the headlights have to be on low beam for the fog lights to work. Check that Richball member. THANKS JIM
Old Oct 8, 2013 | 08:56 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
might be on the bracket kind of behind the brake booster
Old Oct 8, 2013 | 09:24 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Anyone have a pic of the relay and where it is? Replaced the bulbs tonight, low beams on, ignition on... no dice.
Old Oct 8, 2013 | 11:58 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
If my memory serves me correctly it's on the driver's side fender next to where the evap canister is. Should be right by the horn.
Old Oct 9, 2013 | 08:55 AM
Engine: LB9 | LS1
Found it... swapped in another relay, no dice. I will have to check to see if that relay is even getting power. For the '87, is there a separate fuse in the panel for the fog lamps?
Old Oct 9, 2013 | 10:16 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
the diagram says fusible link g, so no not in the panel
Old Oct 9, 2013 | 09:57 PM
Engine: LB9 | LS1
Here is a photo of the visible link. It does not appears distorted in any way. I have not measured the voltage before the link (didn't see an easy open area to the lead), but measuring where the link ends in the socket yields nothing. This is the lead that is always "hot" correct?
Old Oct 10, 2013 | 06:58 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
you cant tell if its good by looking at it you have to use a meter. and the wire that is connected is all brown and melted, you can tell it has taken alot of current at some point. you have to make sure the pin doesnt look damaged and the area were the insulation is melted off isnt permanently damaged
Old Oct 13, 2013 | 01:28 PM
Engine: LB9 | LS1
figure out my problem. after checking all my grounding points, wiring, I decided to take a look at the switch. I removed the switch panel and discovered that I forgot to plug in the swith when I previously removed the gauge panel.
Old Oct 26, 2013 | 10:02 PM
Eric0840's Avatar
Car: 1988 Iroc Z
lol
Old Sep 22, 2014 | 12:14 AM
Jerry DeJane's Avatar
Car: 1988 Iroc Z
Engine: 5.7
Transmission: 700r 4
Axle/Gears: Posi
Hey I know this is old t I am new on this site and was hoping you could help me out. I replaced the dash switch and the bulbs but still no fog light if I turn them on it blows a fuse! Any help would be awesome. Thanks
Old Sep 22, 2014 | 12:19 AM
Car: 1988 Iroc Z
Engine: 5.7
Axle/Gears: Posi
Hello I was hoping you could help me out I am not sure how to navigate this site yet. I replaced the switch and the bulbs and still no lights. When I turn them on it blows a fuse any ideas why is would happen? Also when I get on the gas peddle in gear when I get to higher RPMS it seems to cut power but not when in park. Any help would be awesome
Old Sep 22, 2014 | 12:04 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
you have a short to ground(wire chafed or melted probably) somewhere after the switch.
Old Sep 22, 2014 | 07:50 PM
Car: 1988 Iroc Z
Engine: 5.7
Axle/Gears: Posi
Thanks man found it.
Old Nov 20, 2016 | 01:21 PM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
Old Aug 3, 2025 | 06:23 PM
G70's Avatar
G70
Car: 87 IROC 350, 88 restro mod, 68 conv
Thanks! Very helpful.
Old Oct 13, 2025 | 10:08 PM
pfcastine's Avatar
Car: 1987 Iroc-Z
Engine: Stock 350
Transmission: Stock 5 speed
Axle/Gears: Stock
87 Camaro. Fog lights suddenly stopped working. Switch, relay, and fusible link all test ok. What else could it be? No power to the lights.
(Yes I have the headlights on low beam.)
Thanks for any suggestions.
Pete
jaridjohn
Jul 8, 2024 03:49 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
