Wiring up headlights
Old Nov 3, 2013 | 11:38 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
So the previous owner did me a huge favor and cut all the wires at the firewall and removed all the wiring from under the dash! now instead of going through the headache of that I want to wire up my headlights to a toggle switch. Just until I get the painless wiring kit. How would I go about doing so? I think I saw 5 or 6 wires coming from the headlights...green ones, tan ones and black ones I think..how do I hook them up to a toggle?
Old Nov 3, 2013 | 08:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Wiring up headlights
http://92b4crs.tripod.com/86wiring/dia-pics/100-0.jpg
Old Nov 4, 2013 | 06:02 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
why dont you go get a harness from a car thats the same as yours at the jy, painless is expensive and you would still have to adapt it to your car.
Old Nov 4, 2013 | 08:05 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Cars like mine are scarce at the junkyard.
Old Nov 4, 2013 | 09:01 AM
Joe Tag's Avatar
I can sympathize with you there. If only the was a forum or something like that that was just for third gens. It would be great, they could have a classified section where we could find the parts we need......
Hit the classifieds here, you can find a harness I'm sure. If you plan on just racing the car, toggles are ok. But for actual driveability, and plug and play hook up, I'd go with a factory harness.
Old Nov 4, 2013 | 09:54 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Originally Posted by Joe Tag
I can sympathize with you there. If only the was a forum or something like that that was just for third gens. It would be great, they could have a classified section where we could find the parts we need...... Hit the classifieds here, you can find a harness I'm sure. If you plan on just racing the car, toggles are ok. But for actual driveability, and plug and play hook up, I'd go with a factory harness.
I'm not asking what you would go with, this thread was about wiring up headlights to a toggle. That is what I want to do right now. I figured maybe somebody has done it before and could maybe save me some time.
Old Nov 4, 2013 | 10:37 AM
Joe Tag's Avatar
Well, you said you were going with the painless harness because cars like yours are scarce in a jy. Just saying they're fairly accessible on this site. A factory harness can be put back in in a few hours... much more "painless" than any aftermarket harness.
GL with your project
Old Nov 4, 2013 | 11:51 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
he gave you the diagram up there, you have to get a switch rated for high enough to handle all four on high. then hook one side up to that yellow after the switch and the other to an always hot source. that wont do anything for your running lights or instrument lights or fog lights if you have them, you will have to run separate switches for all those as well
Old Nov 4, 2013 | 08:54 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I figured maybe somebody has done it before ...........
The factory did which is why I posted the headlamp diagram for you to follow.
Read it and put your own switch on the headlamp wires where the factory has one !
And if you want to dim the lights you need the off /On switch and another switch to swap between Hi and Lo beam
Old Nov 5, 2013 | 07:22 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Originally Posted by vetteoz
The factory did which is why I posted the headlamp diagram for you to follow. Read it and put your own switch on the headlamp wires where the factory has one ! And if you want to dim the lights you need the off /On switch and another switch to swap between Hi and Lo beam
For some reason the diagram didn't show up? I clicked it. I would love to have the stock wiring all set up, but it was cut at the firewall and all the dash wiring was yanked out along with the dash and replaced with an aluminum dash. There was absolutely no interior but a racing seat. I finally sourced a car and was able to get all the interior including the dash but again for some reason on the parts car, the wiring was also cut lol. Was anyone else able to see that diagram? I'll post pictures up later so you guys can see what I'm dealing with.
Old Nov 5, 2013 | 03:08 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
works for me
Old Nov 5, 2013 | 03:36 PM
Joe Tag's Avatar
Old Nov 6, 2013 | 12:54 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
would love to have the stock wiring but it was cut at the firewall
No need , we all know what a gutted interior and cut wires look like.
You say you have 3 wires at the lights , ground the black wire and run the other 2 inside to your switch(s) as per the diagram
Question needs to be asked;
why would your buy (unless it was free ? ) a gutted out,what appears to be a race only car and put it back in street trim when you could have bought something that required less or no work just to get it back to stock config ?
Old Nov 6, 2013 | 05:52 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
maybe he wanted a race car that could drive on the street. i got rid of at least 50% of my factory wiring but fortunatly my car was fine to begin with.
regardless rock auto has new switches for ten bucks and new pigtail harness for 22 i think i would go that way. much easier to just put certain things to stock so you know they are engineered and will function properly with your car.
ACDELCO Part # PT1930 {#88860485} 6-WAY FEMALE
Switch Connector-Headlamp Dimmer
Old Nov 6, 2013 | 07:18 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
No need , we all know what a gutted interior and cut wires look like. You say you have 3 wires at the lights , ground the black wire and run the other 2 inside to your switch(s) as per the diagram Question needs to be asked; why would your buy (unless it was free ? ) a gutted out,what appears to be a race only car and put it back in street trim when you could have bought something that required less or no work just to get it back to stock config ?
It was a really good deal, it already came with a lot of good stuff to work with, freshly rebuilt 350, with only 3 passes on it, racing seats, fiberglass hood, 3.73 gears, 5 speed, fresh paint etc. I already put almost all of the interior back in. I was able to source another Camaro that someone was gonna junk and gave the guy 50 bucks and he said I can take whatever I want off of it. They quoted me at the junkyard 250 just for the dash so already I think I'm doing pretty good. Only thing left is the wiring.
Attached Thumbnails Wiring up headlights-image-2654300760.jpg   Wiring up headlights-image-2152791202.jpg   Wiring up headlights-image-3876693111.jpg   Wiring up headlights-image-2414998717.jpg
Old Nov 6, 2013 | 07:20 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
maybe he wanted a race car that could drive on the street. i got rid of at least 50% of my factory wiring but fortunatly my car was fine to begin with. regardless rock auto has new switches for ten bucks and new pigtail harness for 22 i think i would go that way. much easier to just put certain things to stock so you know they are engineered and will function properly with your car. ACDELCO Part # PT1930 {#88860485} 6-WAY FEMALE Switch Connector-Headlamp Dimmer
I'll look into that, thanks!
Old Nov 10, 2013 | 08:18 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Finally got my headlights up and running! Luckily the harness for the headlights wasn't cut at the firewall! The only thing that wasn't hooked up was the ground coming from the headlights. All the wires were cut under the dash though. There were three light green and three tan wires under the dash so I kinda did any many miny moe as to what two to use. Used the original switch that I pulled from the parts car and dimmer switch as well. Luckily the switch harness and dimmer switch connector was all in tact. For some reason I'm not getting my lows but I think I used the wrong tan wire. Now to hook up the rear tail light all I do is connect the brown wire from the tail lights to the switch as well right?
This is what I started with.
Well worth going through all the trouble rather than using toggle switches!
Attached Thumbnails Wiring up headlights-image-4011786842.jpg   Wiring up headlights-image-4290786582.jpg
Old Nov 10, 2013 | 08:23 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
there are browns going alot of places hopefully they didnt cut it.
Old Nov 10, 2013 | 08:28 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Oh boy..this will be fun.
Old Nov 10, 2013 | 07:53 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Is the dimmer switch wired up ?
just need to find the right brown
See
http://92b4crs.tripod.com/86wiring/dia-pics/110-2.jpg
Old Nov 10, 2013 | 09:19 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Is the dimmer switch wired up ? just need to find the right brown See http://92b4crs.tripod.com/86wiring/dia-pics/110-2.jpg
Yes, the dimmer switch is wired up
Old Nov 11, 2013 | 05:44 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
For some reason I'm not getting my lows, the dimmer switch is wired up
So if you have the correct tan wire connected to the dimmer switch, you need to check the switch is working
by putting your DVM on the tan wire at the switch with it in Lo position.
If you have power here need to check the tan wire at the lamps
You have put power on the lamps to show they actually work................
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
Jk_Under
Sep 2, 2015 10:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
stalkier
Aug 13, 2015 12:59 PM
