resistance profile of coolant temp, oil pressure and fuel gauge sensors?
Old Nov 14, 2013 | 08:06 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Does anybody have data sheets or have data points of the sensor resistance for various levels? I want to measure the lfuel level, coolant temp and oil pressure with some data acquisition equipment, but I can't make accurate conversions without these profiles.
Thanks.
Old Nov 14, 2013 | 10:05 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: resistance profile of coolant temp, oil pressure and fuel gauge sensors?
From my '87 FSM Electrical Diagnosis Service Manual Supplement:
Oil Pressure Sender:
90-ohm at max pressure
0-ohm with no pressure
Fuel Gauge Sender:
0-ohm at empty
90-ohm at full
Coolant Temp Sender:
55-ohm at 100F
1365-ohm at 260F
These are measured at the cluster connector.
Old Nov 14, 2013 | 10:07 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I only have the CTS chart.
Attached Thumbnails resistance profile of coolant temp, oil pressure and fuel gauge sensors?-tx3-temp-resistance-chart.gif
Old Nov 15, 2013 | 07:08 AM
Jim85IROC's Avatar
That CTS chart is exactly what I'm looking for. Thank you! Do you know if that represents the CTS for the gauge, or if it's the one that the ECU uses? I'm not sure that they both follow the same profile, since they're both different styles of sensor.
Old Nov 15, 2013 | 02:17 PM
Jim85IROC's Avatar
Thanks to that CTS chart I was able to build a calibration equation (Steinhart–Hart equation) that will allow me to map all of my temperatures without having to resort to a lookup table.
Now if I can just find the same info for the oil pressure sender and the fuel level sender.
Old Nov 16, 2013 | 08:07 AM
Jim85IROC's Avatar
Last night I took apart an old oil sender to see what's inside. The oil pressure appears to push a plunger, which in turn rotates a sweeper pot. I'm going to assume that the sweeper pot is linear. That's provably not completely true, but it should be close.
Likewise, fuel senders use a pot too, so I'm calling that linear too.
Old Nov 16, 2013 | 12:49 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I'm not certain, but my guess is that the fuel level sender is not linear. Typical GM guage that shows 1/2 tank is actually closer to 1/4 tank. It's calibrated so that you can drive 50 miles without moving the needle, the purpose of which is to phsyche out the consumer into thinking he's getting great gas mileage. It reduces warranty complaints.
Old Nov 16, 2013 | 07:56 PM
Jim85IROC's Avatar
I think most of that comes foom the shape of the tank and the gaugeitself, and not necessarily the sender.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
justin57
Aug 20, 2015 07:05 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
