Bouncy gauges?
Old Jan 25, 2014 | 03:46 PM
msgZ28's Avatar
Bouncy gauges?
I recently bought a beautiful '89 IROC-Z 350/5spd. One of the problems that I have is bouncy gauges, particularly the fuel gauge. The other is that the coolant temp gauge doesn't work at all. I haven't had/taken the time to really look into it, but is this a common problem? What most commonly goes bad, the sending unit/sensor or the gauge? Basically, where should I start looking to minimize the time I take looking? I have 2 kids and pregnant wife that can't have me tinkering for too long.
Old Jan 25, 2014 | 03:52 PM
92g92's Avatar
Car: 1992 Camaro Z28
Was the 350 or 5 speed swapped in?
Old Jan 25, 2014 | 04:09 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Lol. Just bought an 89 with 2 kids and prego wife... doesn't want to tinker??? LMFAO good luck dude. These things take LOTS of tinkering!
And congrats. We just had our second boy 4 weeks ago!
Old Jan 25, 2014 | 04:39 PM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
Re: Bouncy gauges?
Between the '89 that I have now, the '85 and '91 that I had before all had gauges that were 'bouncy'.
Old Jan 26, 2014 | 07:22 AM
msgZ28's Avatar
Re: Bouncy gauges?
The 5spd was swapped in. My wife is fine with me working on the car, just not for extended periods anymore. Most stuff will have to wait until her and the kids are in Europe or something and I can have the van and the Camaros. Wasn't hoping to hear that bouncy gauges are normal. Would Autometer gauges or the like help?
jrhaus, Congratulations! Kids are awesome! Except when they're not.....stupid little cockblockers.
Old Jan 26, 2014 | 07:32 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Originally Posted by msgZ28
The 5spd was swapped in. My wife is fine with me working on the car, just not for extended periods anymore. Most stuff will have to wait until her and the kids are in Europe or something and I can have the van and the Camaros. Wasn't hoping to hear that bouncy gauges are normal. Would Autometer gauges or the like help? jrhaus, Congratulations! Kids are awesome! Except when they're not.....stupid little cockblockers.
LMAO!!! Yes, they are great... sometimes!
Old Jan 26, 2014 | 08:04 AM
khulsebus's Avatar
Car: '89 Camaro
Re: Bouncy gauges?
A quality aftermarket gauge can help, or you can send in your original cluster to get re-calibrated. I wouldn't do either without ensuring that the harness is in good condition or replaced with a new one. New gauges with original wiring, still inaccurate gauges. I may be wrong, but I believe that they 'bounce' because they don't have a buffer (like for the fuel level, I don't believe there are baffles in the tank so the fuel sloshes around). I could be wrong, but that's my interpretation.
Old Jan 26, 2014 | 09:30 AM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Bouncy gauges?
The fuel gauge will bounce around due to that there isn't a slosh module to prevent this like there is in newer cars. The sending unit is wired straight to the gauge with nothing to prevent the gauge from bouncing as far as I know. My iroc does this also. I can estimate how much fuel is left just by how far the gauge bounces. Don't know if there is baffles in the tank(haven't seen the inside of mine) but I don't think these would help much if there is as the level will go up and down as the fuel sloshes around. Your temp gauge not working might be the sending unit is just unhooked. Check the wire at the sending unit on the driver side head in between the #1 and #3 spark plugs.
Old Jan 26, 2014 | 07:49 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Bouncy gauges?
Take off the gauge cluster completely and look at the printed circuit board. If it has corrosion on the back and/or damage, replacing it should solve all your problems. It did for me and was only about 80 bucks shipped. While it's out, you can also polish up the lens and upgrade to LED lights as well.
Old Jan 26, 2014 | 08:18 PM
t-top89's Avatar
Re: Bouncy gauges?
check grounds
Old Jan 26, 2014 | 11:11 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Re: Bouncy gauges?
I suggest just taking the cluster off and cleaning all the contacts. Helped my gauges out a lot.
Old Jan 28, 2014 | 06:12 AM
jdm96gsr's Avatar
Re: Bouncy gauges?
Get someone to make a baffle around the sending unit in the tank so sloshing doesnt make the gauge bounce as much.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
