Stripped wires in Engine Bay
Old Jan 26, 2014 | 02:32 PM
Omari149's Avatar
Car: 1987 Camaro Sport Coupe
Engine: V6 2.8L 173cu
Transmission: automatic
Axle/Gears: 4
Hi everyone,
I have a 1987 Camaro SC V6 2.8L 173CU with some unknown wires stripped, cut or disconnected in engine bay on driver side. The car operates fine except for both the high beams its just I'm curious as to what these wires connected to in the past. I am the second owner of the car and this car is my first.
This picture here i guess its part of the headlamp circuit but I don't know what plugs into this connector.
The cut red and black wires that Im holding up was brought to my attention when I got the radiator replaced a few weeks ago, and the mechanic thought it was for a coolant level sensor connector for the radiator but I cant find the connecter that was there originally. Last weekend I went to a auto salvage yard and the 91 and 92 Camaro that I saw there didnt have this wire nor a sensor in the radiator.
Size:  49.6 KBName:  DSC_0127.jpg
The Black wire that I'm holding is grounded to the body, and the red wire is coming from around this device in the pictures.
Thank you for viewing and trying to help out.
Old Jan 26, 2014 | 05:59 PM
Canucksfan1's Avatar
Car: 1987 z28 I-roc
Engine: Carbed 350
Transmission: 700r-4
Axle/Gears: Stock
Re: Stripped wires in Engine Bay
Just a guess but kinda looks like a siren from an aftermarket alarm and the wiring is probably for it
Old Jan 27, 2014 | 12:32 AM
Omari149's Avatar
Axle/Gears: 4
so now I can remove all 4 wires including the siren without damaging anything? thanks Canucksfan1.
I was looking at the wiring diagram for the headlights but I still cant find whats supposed to be connected to that connector that's attached to the headlight circuit.
Old Jan 27, 2014 | 02:01 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Looks like the fog light harness-to-Headlight harness connector......
Old Jan 27, 2014 | 09:58 PM
Omari149's Avatar
Axle/Gears: 4
but there aren't any fog lights on my model. Thanks John in RI for your help.
Old Jan 28, 2014 | 01:41 AM
John in RI's Avatar
Right,.... no fog lights - so no fog light harness connected to that plug.
Your car probably isn't an 'RS', It's probably a Sports Coupe or an LT. There might have been a couple 'RS cars release in 87 - but 88 was the first year of production for the RS cars.
P.S. No Problem !
Old Jan 28, 2014 | 12:16 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
That is definitely an alarm siren. It's not uncommon that they get left behind or disconnected when an alarm malfunctions. Not sure what that connector goes to though...
Old Jan 28, 2014 | 12:53 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
P.S. No Problem !
RS Camaro's were a "California only" model for 1987. For 1988 I believe it included sales to Texas and Florida along with California. 1989 model year, the RS became the "base" Camaro.
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
