Left ignition on overnight ?
Car: 4/89 IROC Z28 G92 -
Engine: LB9 TPI
Axle/Gears: 3.45
It ran the battery down, so I have it charging now. Will this affect anything else ? all the dash lights come on as normal but I haven't started it yet as it's still charging.
Edit: Actually, I think it was just left in so the hand brake light was on.... and not turned to the run possition.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Left ignition on overnight ?
No different than running the battery down any other way.
Engine: LB9 TPI
Axle/Gears: 3.45
Engine: LB9 TPI
Axle/Gears: 3.45
Car: 1983 Z28
Engine: 385 Fastburn
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
I used to have a C6 corvette. I parked it for the winter and 6 weeks later it was dead as a door nail. I guess the smart key receiver keeps searching for the transmitter which was hanging by the car so it killed itself. Put it on the charger overnight and it fired right up. No issues except I had to reset the TPMS and window indexing.
Engine: LB9 TPI
Axle/Gears: 3.45
Thanks for the replys, growing up with the old points ignitions they dislike being left on, the coil would get hot.
It fired right up after a good charge and ran good in the cool night air.
Denricci22
Sep 18, 2015 09:02 AM
