90-92 tpi wiring harness question
Old Apr 7, 2014 | 04:35 PM
custom-crazy's Avatar
Car: 92 rs
Engine: 5.7
Axle/Gears: stock
Will the wiring harness from a 91 corvette c4 tpi fit my 92 rs ecm? Or will i need the corvette ecm as well? Or better question is this even possible?
Attached Thumbnails 90-92 tpi wiring harness question-00h0h_djqreigjlzb_600x450.jpg
Old Apr 7, 2014 | 04:43 PM
Jeffs82TA's Avatar
Re: 90-92 tpi wiring harness question
no way no how two totally different ecm connections
Old Apr 7, 2014 | 04:46 PM
Car: 92 rs
Engine: 5.7
Axle/Gears: stock
ok thanks...
Old Apr 7, 2014 | 04:48 PM
Jeffs82TA's Avatar
If you have a 91 vette harness just get a 7727 ecm and prom. They were mounted under the hood.
If you need one I think I still have my 90 ecm (same as a 91) has chip and all.
Old Apr 7, 2014 | 04:52 PM
Car: 92 rs
Engine: 5.7
Axle/Gears: stock
will it plug right in with all the camaro connectors or will there have to be some adjustments ?
Old Apr 7, 2014 | 04:55 PM
Jeffs82TA's Avatar
No the corvette used like 4 square electrical connectors the f-body used three rectangular ones I believe. You can use a vette harness though and just under hood mount the ecm.
Old Apr 7, 2014 | 04:57 PM
Car: 92 rs
Engine: 5.7
Axle/Gears: stock
how much are you asking shipped to 75243?
Old Apr 7, 2014 | 05:00 PM
Car: 92 rs
Engine: 5.7
Axle/Gears: stock
i have the harness and ecm from a 86 v-8 but im not sure i want to go with a maf sensor... is it possible to put a map sensor on the 86 harness?
Old Apr 7, 2014 | 05:06 PM
Jeffs82TA's Avatar
sounds like a headache for sure,
do you have a vette harness?
Old Apr 7, 2014 | 05:08 PM
Car: 92 rs
Engine: 5.7
Axle/Gears: stock
not yet.. i just found a deal on one.. im trying to go fuel injected... tired of tbi
Old Apr 7, 2014 | 05:11 PM
Jeffs82TA's Avatar
you can re-pin your TBI harness to run TPI
Old Apr 7, 2014 | 05:21 PM
Car: 92 rs
Engine: 5.7
Axle/Gears: stock
Is there a thread somewhere explains what I'll need and the diagram? That would make things a whole lot easier...
Old Apr 7, 2014 | 05:33 PM
Jeffs82TA's Avatar
its here somewhere just can't remember where
Old Apr 7, 2014 | 05:36 PM
Car: 92 rs
Engine: 5.7
Axle/Gears: stock
i may have found it
https://www.thirdgen.org/tbitotpi
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
