painless wiring help
Old Apr 21, 2014 | 10:58 PM
loco823's Avatar
Car: 91 Camaro
Engine: 5.7 v8
Axle/Gears: 2.73 gears
I just installed my new wiring harness 60103 and had a few questions. 1) where exactly does the wire labeled start hook up to. Starter? If so which stud the big or little one. And 2nd) where does the wire labeled ignition go to.? Please help everything is hooked up. I have power but won't start.
Old Apr 21, 2014 | 11:44 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: painless wiring help
https://www.thirdgen.org/forums/tech...formation.html
Old Apr 22, 2014 | 02:09 PM
BJS racing's Avatar
Hi, my name is Jason and I work Tech support for Painless. The red wire with the large ring terminal labeled starter goes to the large terminal where your battery cable goes to on the starter. The wire labeled ignition needs to go to a key on power source that is hot in the start and run position. This wire is the one that will turn the computer on and off.
Old Apr 22, 2014 | 07:54 PM
loco823's Avatar
Car: 91 Camaro
Engine: 5.7 v8
OK I have the ran to the big stud on my starter and for the ignition wire could I tie into the pink wire going to my external coil. Cause that is what I have going on and I have power but the car won't start.
Old Apr 23, 2014 | 07:02 AM
BJS racing's Avatar
Will the motor turn over and just won't fire or will it not turn over? If you want to call me at the office and we can work through it my number is 800 423-9696 ext 1017. Are you getting spark? Do you have a set of noid lights? If you spray carb. cleaner down the throttle body will it fire? How long was this engine sitting?
Old Apr 23, 2014 | 12:10 PM
loco823's Avatar
Car: 91 Camaro
Engine: 5.7 v8
No the motor won't turn over at all and when I try all I hear is a clicking noise coming from the driver side kick panel and if I turn the key all the way on and off I can hear my computer click once. The motor is a crate 350 just got it in and was installing a new wiring harness but when i went to try it out I got nothing.I have the vats removed on the computer also.
Old Apr 23, 2014 | 02:16 PM
BJS racing's Avatar
Ok the engine not turning over is a seperate issue from the fuel injection harness. You need to check the start signal wire going to the starter s terminal from your chassis harness. Are you getting power to the s terminal when you turn the key to the start position? Is the factory wiring still in the car for all of the other functions like headlights and turn signals and what not?
Old Apr 23, 2014 | 10:51 PM
loco823's Avatar
Car: 91 Camaro
Engine: 5.7 v8
Yeah the lights and everything work and the radio is pulled out right now. I'm going to mess with the car tomorrow after work and see what I come up with.
Old Apr 27, 2014 | 07:16 PM
loco823's Avatar
Car: 91 Camaro
Engine: 5.7 v8
ok I got to looking at the car earlier and when I try to turn the car on I can hear it click in the driver side kick panel and it will also click once at the painless wiring harness fuel relay. It still does nothing , the starter doesn't click but I did kind of hear the altenator slightly humming or buzzing when the key is in the on position. really starting to get on my nerves and could really use some advice/help
Old May 1, 2014 | 05:58 PM
bbc632's Avatar
Car: 1990 z
Engine: 383 small block chevy
Transmission: tko 600
Axle/Gears: strange dana 60 4:10
Big red wire says starter goes to the big terminal on top of starter. The purple wire goes to the starter solenoid, then connect the battery positive to the top terminal with the start red wire. Then run the alternater wire to the positive side of the battery or to the same as the other red wires are go. Then make sure you have all good grounds one from the engine block to the body then from the enigne to the frame and the frame to the body and from the frame to the enigne and the batter ground.
Old May 1, 2014 | 07:27 PM
loco823's Avatar
Car: 91 Camaro
Engine: 5.7 v8
Kk I'll try that. I know for a fact that I don't have a ground from my frame to my motor
Old May 1, 2014 | 07:53 PM
bbc632's Avatar
Car: 1990 z
I bet the grounds are your problem.
Old May 1, 2014 | 09:08 PM
loco823's Avatar
Car: 91 Camaro
Engine: 5.7 v8
I hope so. Is starting to get on my nerves now
Old May 13, 2014 | 10:40 PM
loco823's Avatar
Car: 91 Camaro
Engine: 5.7 v8
OK update. I just got the motor to turn over but it didn't fire up. There is 3 post in my starter and I had the signal wire hooked up to the wrong post. When I try to start the car it backfires could it be the timing? I haven't checked for spark yet because it is getting dark. Man alot of weight has been lifted off of my shoulders hearing the motor turn.
Old May 13, 2014 | 11:05 PM
bbc632's Avatar
Car: 1990 z
Glad to hear it's turning over just don't keep turning it over, I would go ahead and bring #1 piston to top dead center!!! Then pull the dizzy out with it out check rotor button and cap. Then if it's all good install the dizzy back. And go ahead and get some new ac Delco spark plugs there great plugs. Makes your getting fuel and the carb filter is clean then start it up! And when you do get it started up bring the motor to 3000 rpm and should set the total advance around 34-36 degrees BFTD. And then you should be good to go. Hope this helps jay. If you need to call me you can just pm me and I'll give you my cell.
Old May 13, 2014 | 11:10 PM
loco823's Avatar
Car: 91 Camaro
Engine: 5.7 v8
Kk ty for the advice I'll try that tomorrow after work.
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
Ducati900ss
Sep 2, 2015 09:05 AM
stalkier
Aug 21, 2015 01:54 AM
squiggy2
Aug 9, 2015 09:30 PM
