Neutral Safety Switch help!
Old May 9, 2014 | 02:31 PM
BrandonTheZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 350 V8
Transmission: 5 Speed
I've been trying to find out where the neutral safety switch is on my 85 camaro 5 speed trans? I want to know where to bypass it or get a new one. I've went to part stores and have it for auto trans but not manual trans. Need help . Please post pics on where it is on a manual trans and how to bypass it.
Old May 9, 2014 | 04:35 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Neutral Safety Switch help!
What are you trying to bypass? A manual trans does not use a Neutral Safety switch, it has no way to detect a neutral position.
Old May 9, 2014 | 04:39 PM
Engine: 5.7 350 V8
Then what is this thing connected to my clutch pedal then?
Old May 9, 2014 | 04:44 PM
Lurbie's Avatar
Car: 89 Camaro
That's the Clutch Pedal Position switch. Keeps you from accidentally starting the car without having the clutch applied. I wouldn't bypass that, at a minimum, you could wreck your car, worse case scenario you could hit someone.
Old May 9, 2014 | 04:49 PM
Engine: 5.7 350 V8
Mines disconnected and hasn't been connected since i owned it. Could that affect my car starting?
Old May 9, 2014 | 04:55 PM
Lurbie's Avatar
Car: 89 Camaro
It's designed to keep the engine from cranking if you don't have your foot on the pedal, but if the car just recently won't crank, sounds like it was bypassed somewhere else and that jumper came loose or maybe a connector somewhere else came loose. When you try to start the car, do you have voltage at the Purple wire? IIRC the voltage should go through your ignition switch, through the Clutch Pedal Position switch (also called a Starter Safey Switch sometimes), then to the starter solenoid.
Old May 9, 2014 | 05:14 PM
Engine: 5.7 350 V8
Nothing happens when I turn my key.no cranking or anything, yeah i did find a little cable on my floor looks like it bridges 2 things together but idk where it would go
Old May 9, 2014 | 05:51 PM
Lurbie's Avatar
Car: 89 Camaro
Here's a schematic of it.
Old May 9, 2014 | 06:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Lie on floor , put head by brake pedal and look up
There is /was a switch on the clutch pedal
The connector that went there is most likely where the jumper you have found came from
Old Aug 18, 2014 | 05:59 PM
jfl1960's Avatar
wrong post sorry.
MM2Robinson
Oct 1, 2017 09:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Randomtask2
Sep 10, 2015 08:37 AM
Fronzizzle
Sep 8, 2015 12:10 PM
