hot wire when key is turned on
Old Sep 10, 2014 | 08:14 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
Was trying to find what wire is soot to splice into that is hot when I turn the key? 1986 trans am
Old Sep 12, 2014 | 06:15 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: hot wire when key is turned on
That's quite vague. Any wire is safe to splice, the problem is, what are you adding to the circuit ? If what your adding is to big a draw on the circuit, you'll just pop fuses or smoke the wiring.
This should help...
http://www.austinthirdgen.org/?pid=19
Old Sep 12, 2014 | 06:21 PM
happyhapka's Avatar
It is for a guage... I need it turned on when the car is on but off when the car is off.
Old Sep 12, 2014 | 06:40 PM
deadbird's Avatar
Engine: TPI 305/ v6
Gages, radio, wiper, htr a/c, c/h fan, turn b/u fuses are all ign switched
If you look at fuse panel, there's a empty terminal labeled ign, you can stick a male spade terminal in as well iirc
Old Sep 12, 2014 | 06:44 PM
happyhapka's Avatar
Glowsock
Jul 24, 2025 03:15 PM
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
ZsTransAm
Aug 11, 2015 07:30 PM
