87' tpi harness into 89' v6
Old Nov 13, 2014 | 08:18 PM
Ciucakid's Avatar
This isn't an engine swap question. I already have reviewed and looked over that forum and know what else I need to accomplish. This is solely, what differences/problems am I going to run into with trying to take an 87' 305 tpi harness and computer and try to put it in an 89' v6 car.. I was going to keep the v6 harness in the car and just hardwire a 350 in around it. But the opportunity for a 305 tpi harness and motor have kinda fallen in my lap. if this will be easier and cheaper, I will go this route. But I don't want to be cutting,splicing, and putting new connectors on wires.. I want to plug and play. Where there differences between these years and harnesses that wont permit such an easy use? Such as wipers,headlights, main firewall connection below master cylinder? I appreciate input and knowledge if anyone has already tried this. Thank you
Old Nov 13, 2014 | 10:23 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 87' tpi harness into 89' v6
87 harness into an 89 car does not = Plug-&-Play.
You can get the schematics for the C100 connector ( Dash-to-Engine ) and the C207 connector ( Dash-to-ECM ) harnesses from these 2 links. Print out both the 87 and the 89 schematics and start working thru each and every wire to see what matches up and what doesn't.
C100
http://berlinetta.info/C100.htm
C207
http://berlinetta.info/C207.htm
Off the top of my head; The 87 & the 88 wiper and injector wiring is not compatible and needs to be 'fixed'.
* 87 has Wiper wiring in Engine harness..... 89 has the Wiper wiring in the Headlight harness.
* 87 Injector wiring is connected @ plug C221,... 89 doesn't have a C221 plug. ( C221is also shown in links provided. )
Expect some re-wiring in order to get this combination of parts to work together.......
stalkier
Dec 6, 2015 11:25 PM
armybyrd
Dec 5, 2015 09:22 AM
fbirdroller
Sep 2, 2015 10:27 PM
IBrockZ
Aug 20, 2015 12:20 PM
Sanjay
Aug 12, 2015 03:41 PM
