89 GTA lost keys what to do next?
Old Nov 19, 2014 | 07:48 PM
ratinfested's Avatar
lost the keys to my 89 gta i just picked up. have the key with the resistor. want to know what my options are to remedy this. can i put a regular ignition in it and bypass the security thing? security thing is a pain anyway, away have to wait a few minutes to start it.
Old Nov 19, 2014 | 08:52 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: 89 GTA lost keys what to do next?
I don't understand.
Are you saying that you have the key with resister in it for the car. ? If you don't have the exact key with resistor pellet for the car than that really complicates things.
The best thing you could do is remove the EPROM Module from the ECM and send it off to have VATS removed.
Once that's done you can either change out the key cylinder for a new one with a regular key.
(The resistor pellet is no longer necessary.) or have one made for the cylinder you have.
Then I would bypass the VATS Enable Relay.
At this point you will be driving a car with no security system.
You can install a kill switch or a aftermarket system or both.
Old Nov 19, 2014 | 08:59 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Take your ID, VIN number and proof that you own the car to a good dealer. They can cut keys for it, if they haven't been changed.
Old Nov 19, 2014 | 09:55 PM
Engine: TBI,5.0
I really hope that works for you.
My way you would need a crash course in VATS 101/ECM/EPROM Removal......
Still a good way to go if you want VATS disabled .
It's actually really easy to do and I have a detailed description with photos concerning the procedure if needed.
Old Nov 20, 2014 | 03:32 PM
i "Had" the type of key with resistor. i will try dealer, would i go to chevy dealer since there is no pontiac now? Need to clean my truck, may be in there but not looking good.
Old Nov 20, 2014 | 05:34 PM
FOUND THEM!!!!!!!!! in pocket on my truck door. put them in there last time i worked on the trans am. thatnks for the replies!
Old Nov 20, 2014 | 06:05 PM
Pocket's Avatar
Car: 91 Trans Am
For future reference, use a meter to ohm out the resistor value. Write it down somewhere, so replacement keys only need a blank matching that value and can be cut anywhere for $2
Old Nov 20, 2014 | 10:05 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Or take an assortment pack of diode resistors. Measure the impedance and just tie it in to jump the circuit. Just a little something from old school. LOL.
Old Nov 21, 2014 | 03:38 PM
jimmykicker's Avatar
I lost mine one time for 6 months...Sitting on the couch and I thought out of nowhere..."I know where my keys are!" They had fell out of a jacket I was wearing. When I hung the jacket up they fell into the arm of a sweater that was on the same coat rack...
Fortunately I didn't have any keys with the security resistor and I had spares....
Glad you found them!
armybyrd
Dec 5, 2015 09:22 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
GouldyGTR
Sep 7, 2015 09:05 PM
Gunsbee
Sep 7, 2015 07:10 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
