12v when engine is running
Old Jan 12, 2015 | 09:56 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
Does anyone know what wire has 12v when the engine is running? Or how I can get a wire that has 12v when engine is running? Thanks
Old Jan 12, 2015 | 09:59 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 12v when engine is running
Ypu might want to state what your wiring up. Are you looking for a switched acc power source for a radio or amplifier ?
Old Jan 12, 2015 | 10:06 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Use a test light. http://www.amazon.com/s/?ie=UTF8&key...l_5gf1io567t_e
Old Jan 13, 2015 | 06:20 AM
Engine: 5.7 350 TPI
I'm looking to run my dual electric fans when the engine is running only. Because right now if the engine is warmed up to temp the fans will stay on when the ignition is on the "on" position. I need a 12v wire when engine is running so I can run that to the fan relay so it only comes on with when the engine is running
Old Jan 13, 2015 | 06:21 AM
Engine: 5.7 350 TPI
Originally Posted by red rock
Used a test light but no solution. I tested wires under the steering column
Old Jan 13, 2015 | 11:37 AM
Engine: Lb9
Transmission: M20
The fan relays arepa the bulkhead next to your master cylinder.
Assuming this is tpi the primary fan is controlled bye the ECM and the secondary is controlled bye d11 of the ECM or when the ac is commanded on or if the cylinder temp switch between cylinder 6&8 hits 228f and grounds the fan relay. Wiring it back to stock would be advisable. If this is tbi you just have the secondary wiring circuit without ECM control.iirc on 89 gm went to better relays with weather pack connectors previous years had relay connection issues melting the wires at the relay. Swapping to the newer relay pigtails is a great upgrade.
Old Jan 13, 2015 | 11:41 AM
Engine: Lb9
Transmission: M20
Old Jan 13, 2015 | 11:54 AM
Engine: Lb9
Transmission: M20
14089936 gm acdelco 15-8240 relay part number ,acdelco pigtail pt1115
Caspar
Jun 19, 2016 11:19 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
