87 dizzy to 85 wiring
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
85 z28 305tpi changed to a 350 tpi. the 350 came out of a 87 ta.The block casting date is 88 though. has the small dizzy and v belt stuff. the 85 stock wiring is for the larger dizzy with the coil in cap. I think this is my last hurdle. I gota get either the wiring changed or the dizzy. the gear on a carb dizzy looks just like the gear on the small cap 350 dizzy. I'm hoping I can just change the conectors on the 85 harness and drop the motor in.Help!
Axle/Gears: 273?277
Re: 87 dizzy to 85 wiring
I picked up the ecm out of the car i got the motor from
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Iirc the wires from the 85-86 large cap are the same color as the 87-92 small cap connecter.
http://tpiparts.net/inc/sdetail/6848
Iirc two wires switch position on the icm it's been awhile since I have made the conversion pigtails.
junkcltr
Aug 2, 2019 11:12 PM
