replacing ignition switch?
Old Feb 9, 2015 | 12:14 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
I bought a 89 firebird rolling chassis and was wondering if I need a certain switch since I'm assuming 89 had vats. I'm replacing all the locks since I don't have any keys.
Old Feb 9, 2015 | 06:08 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Re: replacing ignition switch?
It depends on the engine computer you get and more importantly the wiring harness.
Old Feb 10, 2015 | 01:25 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
I'll be going with a non computer controlled carb setup
Old Feb 11, 2015 | 07:42 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Bump
Old Feb 11, 2015 | 08:00 PM
alex722607's Avatar
You only needs vats if you retain the starter enable circuit or the fuel enable circuit. Since your going with carb and not FI and the starter enable can be bypassed you do not need the VATS ignition switch
Old Feb 11, 2015 | 08:02 PM
VATS isn't in the ignition switch.
It's not in the lock cylinder, either, but, the cyl is at least in the chain of things.
From your description, you're working on the latter.
All that's there, is a set of contacts to connect to the VATS resistor in the key. That's all. None of the "intelligence" (if I may be so bold as to apply such a word, in 2014, to VATS) lives in the lock cylinder.
You don't have to worry about it. Just get the right lock cyl for your car, install it right, and move on.
Old Feb 11, 2015 | 09:06 PM
alex722607's Avatar
Yea I know I was just being lazy and didn't explain. But also if you get the lock cyl for vats isn't it more expensive? Idk
Old Feb 12, 2015 | 07:42 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Ok so just a regular ignition switch and I won't have any issues?
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
