Missing/spliced ypipe O2 wiring
Old Mar 11, 2015 | 11:38 AM
dsebastian0127's Avatar
Car: 92 Camaro RS 25th
Engine: 3.1 V6
I have a 92 camaro rs with the 3.1 auto. I need to replace the O2 sensor on the y pipe but the PO has fubared the wiring. After reading I've seen the that O2 sensor is supposed to run to a purple wire and the knock sensor which would be the closest sensor if I'm correct is supposed to run to a green wire coming out of the same harness. The problem is the purple wire has been cut and spliced into what I believe is the knock sensor and the green wire is MIA. I've been following wiring diagrams with little help. I would greatly appreciate any and all suggestions or advice. I will gladly post any pics needed just let me know what will be helpful.
Old Apr 3, 2015 | 09:55 AM
Engine: 3.1 V6
Re: Missing/spliced ypipe O2 wiring
Bump
armybyrd
Dec 5, 2015 09:22 AM
89fbirdformula
59
Mar 11, 2011 05:06 PM
KamikazeIroccy
Apr 3, 2008 07:35 PM
pskel350
Mid-West Region
23
Feb 22, 2005 09:35 PM
JMatlock88
Aug 24, 2002 05:20 PM
