HELP! won't crank, VATS?
Old Jun 9, 2015 | 02:32 PM
dibella989's Avatar
Car: 1988 Trans Am GTA
Transmission: 5-Speed
Axle/Gears: 3:45
Just removed the wheel to replace turn signal switch, now won't even crank over. It is a 1988 Trans Am GTA with the factory security system. The security system is the only thing I think it could be, how can I bypass it, or what else should I be looking into?
Old Jun 9, 2015 | 02:58 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: HELP! won't crank, VATS?
the two white wires in the orange sleeve that runs down through the column might of gotten pinched. Look in the column some more. If it cranked before, it should crank now. Unless of course, you left the door open and drained the battery while you were doing the repair!
Old Jun 9, 2015 | 03:20 PM
dibella989's Avatar
Axle/Gears: 3:45
I was in the middle of the repair and realized I had to go to O'Reilly, the wheel hadn't been broken loose, just the bolt loosened and horn wire detached, so I put it together and didn't start. First thing I tried doing was charging the battery. Do I need to pull the wheel in order to take the panels off of the column?
Old Jun 17, 2015 | 06:47 PM
DanZ281990's Avatar
Does anyone know how to hook up a baker electronix vats bypass module? Like which wires do I hook this thing up to? I have a 93 Camaro z28
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 22, 2015 03:19 PM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
