Battery water levels
Old Dec 18, 2001 | 12:19 PM
nosaint's Avatar
Car: 1986 Trans Am
My car has been dying as of late. It seems to hold
a charge for a day and then its dead. I just checked the level of water and they were really low. Is that battery toast now or will it hold a
charge now that I have added fluid?
Old Dec 18, 2001 | 05:30 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'm not sure if it'll help you now but, Autozone sells an additive to add to your weak battery that supposed to help 'restore' it. I used it a long time ago & remember it helping somewhat for awhile.
It's very similar to the stuff JCWhitney sells here
$6 & some water (if it helps) is better than a $40-60 battery.
Old Dec 20, 2001 | 04:17 PM
nosaint's Avatar
Car: 1986 Trans Am
Its not to often I get to answer my own questions but here is goes. After i added water (I know your suppose to use distilled) my battery failed an test at the local auto store. I got myself a new battery and then had a bad cable. I got myself a new cable and then I had a bad swith to the the starter kill relay. I got a new switch and would you believe my car actually started! Well have to see where it decides to strand me tomorrow.....
i hope not!
Old Dec 21, 2001 | 01:15 PM
nosaint's Avatar
Car: 1986 Trans Am
Well it started fine and I let it run for about 20 min. I got into it and put it into gear and it died. It cranked for about 10 seconds and then this brand new, Eliminator battery with 900 cold cranking amps was dead too.
any ideas? Like maybe the alarm kicked in or something?
Old Dec 21, 2001 | 02:00 PM
deadbird's Avatar
Engine: TPI 305/ v6
If the battery is dead, it sounds a little like your alternator may not be doing it's job anymore. Did you watch the voltage any while it was running ?
Old Dec 24, 2001 | 08:21 AM
gmanuel's Avatar
Have you found out why the engine stalled when you put into gear? I would check the alternator to see if it is charging. Then I would look to something that is drawing power. Like the little light in the chargo area or the dome light not turning off.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
customblackbird
Oct 1, 2015 04:30 PM
gta892000
Sep 16, 2015 12:37 AM
