Can someone double check my wiring please
Old Jul 1, 2015 | 09:39 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Axle/Gears: ls1 rear with 3.23
Using holley efi to control fans
Old Jul 1, 2015 | 11:22 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Can someone double check my wiring please
Looks fine to me with one small revision ;
I'm not so sure a single 20 amp fuse will handle both fans like that , Maybe use a 20 on each relay at the #30 terminal , so that each fan has it's own 20 ....
Old Jul 2, 2015 | 04:35 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Fans do draw a lot of power, stock setups use fuse link or 40A fuse for dual fans.
I don't know how your EFI computer works, but I assume it has plenty of flexibility. For the control side of the relays, you might want to have the computer switch ground instead of 12v. Also, if you can have the computer control the on/off at 2 different temperatures for each fan, the huge power rush will be cut in half when the fans first come on.
But it will work the way you have it.
Old Jul 2, 2015 | 10:46 AM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Awesome thanks guys. I will add another 20amp fuse for each fan. Im not sure why i overlooked that.
Thanks for the help/replies
Infested
May 22, 2018 11:56 PM
armybyrd
Dec 5, 2015 09:22 AM
djmarch
Aug 19, 2015 12:07 PM
tnrednneck
Aug 13, 2015 08:57 AM
