Updated wiper issue- stalk is very sensitive.
Car: 1983 Z-28
Engine: 305 LG4
Transmission: 5-speed
So yea, when I use the turn signal it turns on wipers...it's one of the quirky little issues that I have. Would this be the multi-function switch?
My Dad replaced the steering column at some point, as it had been busted open years ago when it was stolen. He might have mis-connected something. I have other issues like no power to the passenger door, washer fluid motor doesn't work, no door chime, etc...
Car: 90 Iroc Vert
Engine: 5.0L
Re: using the turn signal turns on wipers
Try stalk, ebay $15.99 .... search Camaro turn signal stalk.
Fixed my cruise control, metal rod in center gets rusty, looses ground. May fix your washer fluid thing too.
Easy to install, pull old - (pull hard, pops out), fish thru column, plugs in.
Car: 1983 Z-28
Engine: 305 LG4
Thanks for the reply... I'm a little confused though. I pulled the stalk out, but no wires to fish through, it's just a metal rod, looks clean and in good shape. Not doubting you, but you think replacing it will really help?
Car: 90 Iroc Vert
Engine: 5.0L
Yep, should be a cable/wire with a plug on the end ... wire probably operated wipers & cruz ... There should be a white plug down above the break pedal that accepts the stalk plug.
Car: 1983 Z-28
Engine: 305 LG4
Re: Updated wiper issue- stalk is very sensitive.
I pulled the stalk from the column again, and realized that the wipers go on at the slightest touch of the stalk... they even go on if I touch the base of the column where the stalk goes in! (see photo)... what would cause this?
Car: 90 Iroc Vert
Engine: 5.0L
Stalk is ground operated, your body is acting as the ground when you touch it ? Just a hypo theory ?? As I said above my stalk metal rod was rusty, new one made everything work. Or you could have a broken wire in there.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Your car probably doesn't have cruise control.That's what the harness on the stalk is for, nothing else.The switch/wires for the wipers is on the column.
The stalk acts as a **** of sorts for the wiper control, but the actual switch is in the column.Sounds like you're grounding something when you touch the stalk.
Your hi-beam is also incorporated into the switch, again the stalk is just a way to reach in & activate the hi-beams.
Car: 1983 Z-28
Engine: 305 LG4
Yea, no cruise control. Hi beams work fine... I see where the wire harness is now. When I can, I'll take a better look at the wires and see if one is broken or something.
