Headlight issue
Old Mar 3, 2016 | 09:06 AM
instaldave's Avatar
Car: 1987 Trans AM
Engine: 355 4-bolt, L98 heads, Holley 650DP
Axle/Gears: 3.70 9-bolt
Headlight issue
I went to move the car last night 87 TA and when I hit the switch for the headlamps the interior lights on the dash didn't illuminate and the passenger headlamp isn't going down. The motor isn't even trying. I'd say maybe the motor went but the fact that the interior lights aren't working either tells me its something more. I tried the dimmer switch. No reason it would of made a difference but I tried anyway.
Thoughts?
Old Mar 4, 2016 | 06:23 AM
instaldave's Avatar
Car: 1987 Trans AM
Re: Headlight issue
Well I'm not getting very far with this. I'll try rephrasing the question. Can someone please provide me with wiring for the headlamp switch, dimmer, headlamp controller under the hood, and to the headlamps?
Old Mar 7, 2016 | 06:29 AM
instaldave's Avatar
Car: 1987 Trans AM
Re: Headlight issue
It was a blown 15amp fuse. I'll just see myself out now.
Old Apr 13, 2016 | 11:34 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Headlight issue
Was it labeled "Tail light"?
Lon
Old Apr 14, 2016 | 06:25 AM
instaldave's Avatar
Car: 1987 Trans AM
Re: Headlight issue
I actually don't know what the fuse was labeled. The labels are all faded away at this point. I just started checking the fuses and came across a blown one.
Old Apr 14, 2016 | 09:01 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Headlight issue
Print this out and stick it in your glove-box !!! Should be accurate for your 87 Firebird.
** notice none of them call for a 15 AMP !
Old Apr 14, 2016 | 09:50 PM
mk1431's Avatar
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
Re: Headlight issue
why did it blow is there a problem?
Old Apr 15, 2016 | 06:16 AM
instaldave's Avatar
Car: 1987 Trans AM
Re: Headlight issue
I'm not sure why the fuse blew. The car was mechanically and electrically jury rigged when I got it. I have been going through it trying to fix everything I find. But its a process. This summer I'd like to pull the whole harness out of the car and start fresh. It has been tampered with way to much. I had a bad headlamp motor that could have been putting a strain on the system and the current spiked trying to work it. It has since been replaced.
Cross fire Sid
Camaros Wanted
22
Mar 17, 2016 03:48 PM
ILMODC
Mar 7, 2016 01:11 PM
scarr001
Mar 6, 2016 07:20 PM
Adrianm5
Mar 4, 2016 04:56 PM
Dads91camaro
Interior Parts Wanted
Mar 2, 2016 06:34 PM
