CANT FIND THE CONNECTION UNDER DASH FOR WIPER STALK
Old May 31, 2016 | 01:01 PM
RandyTyler2's Avatar
Car: 1986 Firebird
Engine: 350 Carbed
Hell I have run into a problem. Someone before that owned the 1986 Firebird put a after market wiper stalk in it. What i want to do is put a original wiper stalk back in. I ca not find the connecter to plug the wiper stalk connecter to it under the dash. Can someone please post a picture of the wiper stalk connects to under dash. HELP
Old May 31, 2016 | 01:06 PM
Twin_Turbo's Avatar
Re: CANT FIND THE CONNECTION UNDER DASH FOR WIPER STALK
the only connection external of the column is if you have cruise control. the blade type connector goes into this one
photo courtesy of someone else here on thirdgen, found through google
Old May 31, 2016 | 01:16 PM
Car: 1986 Firebird
Engine: 350 Carbed
This 1986 Firebird has no cruise and no wiper delay. That connecter in picture does not look familiar, I am not seeing anything like that, but I will look again...
Old May 31, 2016 | 01:18 PM
Car: 1986 Firebird
Engine: 350 Carbed
in the pictuer there are two connectors is it the small one or large? Another thing is , is it a blade connecter?
Old May 31, 2016 | 01:20 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The wiper connector is a flat looking plug and the under dash part it goes into is a normal looking plastic connector. Its odd how gm did it but it had to be able to snake down the column for replacement.
Old May 31, 2016 | 02:21 PM
Car: 1986 Firebird
Engine: 350 Carbed
Man Just dont have that connecter...maybe it was cut off. Do you know the colors of the wires. Trying to figure out which of the connectors in pic it is?
Old May 31, 2016 | 03:58 PM
i88aGT's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: No G92
Hi, is everything working the way you want it to and you just want to replace the physical lever? If so the multifunction lever just pulls out. I believe you set everything to 'off' and pull straight out. Correct me if I'm wrong, but I think this is all you'd have to replace.
If your car doesn't have cruise then there shouldn't be any wires attached to it to fish in or out of the column, see the cruise control is connected to the stalk, but the wiper functions are connected to a switch inside the column.
If this is not the case and you need to replace that switch inside the column, here is a picture of a 1986 firebird column A/T, no delay, I happen to have in my closet (rofl). It is the shorter connector on the right, I believe.
https://drive.google.com/file/d/0B3_...ew?usp=sharing
Old May 31, 2016 | 04:26 PM
TTOP350's Avatar
90-92 air bag cars its that easy. You just pull it out and unhook the little connector right there behind the removable cover.
On 82-89 cars the wires run all the way down to the bottom of the column for the multi function switch
Old May 31, 2016 | 04:36 PM
i88aGT's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: No G92
right, so if for some reason he has to replace the wiper switch inside he has to tear into the column and unmoumnt the switch, and unplug that connector i show on the right, and take off the wire guard cover, and fish the switch's wires up and out.
but that's only if the stalk/multifunction lever isnt compatible with the switch that's already in there, correct? i was thinking maybe since all he has is non delay wiper he can pop the stalk in and it'll operate the switch ok.
Old May 31, 2016 | 04:46 PM
Car: 1986 Firebird
Engine: 350 Carbed
Hey guys I feel kind of dumb after looking at it more and getting your advice. Without cruise control there is no wire to attach Its all in the switch. So what i need is a wiper stalk with no cruise. The switch does the work.It feels like the switch may be bad it is really sloppy. So now to find a switch that will work for this year car. What fooled me was the aftermarket cruise control they put in It had the wire in the column
Old May 31, 2016 | 04:48 PM
i88aGT's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: No G92
which part is floppy the blinker action or the wiper action?
Old May 31, 2016 | 04:52 PM
TTOP350's Avatar
Well, that solves that, a little bit.
Old May 31, 2016 | 06:21 PM
Car: 1986 Firebird
Engine: 350 Carbed
The wiper action seems sloppy, blinker part works fine. I guess the first thing to do is get the right wiper stalk. Maybe that will all of the problem...Lol
Old May 31, 2016 | 06:26 PM
Car: 1986 Firebird
Engine: 350 Carbed
I did get this done over the winter A little mod to the hood...I bought 1977 T/A Shaker and installed on car...cut the hood for shaker
Old May 31, 2016 | 06:46 PM
Car: 1986 Firebird
Engine: 350 Carbed
thanks for the advice everybody
Old May 31, 2016 | 07:41 PM
i88aGT's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: No G92
the shaker looks pretty cool, good job.
my brother used to have a black '79 ta with the silver and red bird.
Maybe you can figure out how to hide the wipers better to complete the stealthy look.
Old May 31, 2016 | 09:33 PM
Car: 1986 Firebird
Engine: 350 Carbed
well thats why I was working on wiper problem. They are not down where they are suppose to be....
Old Jun 1, 2016 | 12:23 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
That adjustment is in the cowl area, on the wiper linkage.Does the dr.side wiper go past the pillar?
Old Jun 1, 2016 | 04:07 PM
Car: 1986 Firebird
Engine: 350 Carbed
Hi, the problem is the switch in the steering column. It is broke on the inside. When I put fuse in the wipers will not turn off. Been looking for a switch they run from $90.00 to $138.00. Kind of expensive right now. This one is $90.00 I think that is the correct one?
xbazzarex
Sep 11, 2016 02:38 PM
ponttpi86
Apr 27, 2016 09:28 PM
ponttpi86
Apr 27, 2016 08:19 PM
B4C5.7
Apr 8, 2016 05:40 AM
jakemack96
Mar 29, 2016 09:23 AM
