Injectors on engine off.
Old Sep 8, 2016 | 11:08 AM
94ElBanditoDeCa's Avatar
Car: 88 Trans AM
Engine: 5.0 TPI
Transmission: BW T5
My Fuel injectors on my 88 5.0 TPI firebird are always running constantly with the key on and engine off. It's causing my engine to flood. I don't know where to start.
Old Sep 8, 2016 | 11:18 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Injectors on engine off.
Grounds at the back of engine heads
Old Sep 8, 2016 | 12:21 PM
Car: 88 Trans AM
Engine: 5.0 TPI
Transmission: BW T5
Which one?
I changed my ICM the other day and the car was running fine all day yesterday. Could it be close to the distributor?
My fuel pump keeps priming too and won't stop.
Old Sep 8, 2016 | 12:40 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I would check all but start with drivers side head
Old Sep 8, 2016 | 12:46 PM
Car: 88 Trans AM
Engine: 5.0 TPI
Transmission: BW T5
What ground though? The one that grounds from the head to the firewall?
Old Sep 8, 2016 | 12:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Harness ground on back of driver head. Look for it
Old Sep 8, 2016 | 12:54 PM
OrangeBird's Avatar
Car: 1989 Firebird
Which one?
My thought here is that your new ICM has malfunctioned in such a way that it's got the ECM thinking the engine is running when it actually is not .
The ECM knows to keep the pump on and when to spray the fuel from a signal the ICM sends it when the distributor is turning . If what your describing is what I think it is , this is the first time ever I've heard of an ICM malfunctioning in that way . Of course with electronics we "never say never" and even though by far the most common failure of an ICM is simply to make no spark , there is nothing ironclad that says it couldn't malfunction in the way I suspect yours might have . To test this I would unplug the ICM and if the pump and injectors are now stopped with the key on then I'd get that ICM back to where it came from for an exchange , provided your grounds all check out as previously suggested .....
Old Sep 8, 2016 | 11:15 PM
Car: 88 Trans AM
Engine: 5.0 TPI
Transmission: BW T5
I checked my ground connections just like you mentioned and everything looked good. I pulled the ICM off as soon as I got home from school and the problem with my fuel injectors and fuel pump constantly running went away! So I ran over to the parts store, explained to the guys my situation. I got the impression that they thought I was crazy but they gave me a new ICM anyways. I plugged it in, turned the key on, and bam! My problem was gone! My car started right up after I had to unflood my cylinders of all the gas that stayed in there.
Thank you guys so much.
Old Sep 9, 2016 | 06:10 PM
OrangeBird's Avatar
Car: 1989 Firebird
Oh , and , an oil change might be a good idea right about now , seeing how all that extra fuel leaked past the rings into the oil , and loosened all kinds of crud that's now in the oil filter ....
Old Sep 10, 2016 | 08:46 PM
Car: 88 Trans AM
Engine: 5.0 TPI
Transmission: BW T5
I spoke too soon. It happened all over again. Exactly the same way. Car died, fuel pump and injectors constantly running, disconnected ICM, and it all stopped. I had to buy another one to fix the problem.
At this point I'm pissed off. Could I be unlucky and have gotten two bad modules? Is there any way I can test the module with an Ohms meter? My grounds look fine.
I found a half chewed up but still good spark plug wire so could this cause the problem?
FormulasOnly
Sep 26, 2016 06:21 AM
Dracula
Carburetors
26
Sep 24, 2016 08:00 AM
80's Al
South East Region
16
Sep 22, 2016 12:32 PM
DuramaxJut
Sep 3, 2016 08:12 PM
92GTA
Aug 28, 2016 04:13 PM
