Long term storage options & fuel injectors
Old Aug 27, 2016 | 06:54 AM
92GTA's Avatar
In the next week I need to prep my 92 to go in my seatrain so I can come back to the US for work. I'm not gonna lie, it could be 3-4 years until I am able to put the interior back together after she was painted a year ago and get her back on the road.
What are my options to save the fuel pump and fuel injectors? I have virtually brand new Bosch III fuel injectors and Walbro pump.
I can only think of 2 options:
A) Put a tiny bit of fresh fuel into the tank, start her up, and let her run out of gas (not good for my Denso heated o2 sensor)
B) Put in a little bit of gas with some sort of fuel stabilizer that will keep the injectors and fuel pump from guming up as the fuel ages. I think my options that I've seen on the island are SeaFoam, MMO, and Sta-Bil.
C) Open to suggestions lol.
Thanks!
Old Aug 27, 2016 | 07:22 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Long term storage options & fuel injectors
Fill the tank full of non-corn fuel and use a stabilizer of choice.
I just fired up my car that had been sitting 4.5 yrs with just regular 93 octane in it and it ran. Took it easy till the old crap was used up and its fine.
Old Aug 27, 2016 | 07:25 AM
92GTA's Avatar
AWESOME! Thankfully non-ethanol fuel is all there is on the island haha!
I'll go with SeaFoam then, that's my trusted brand and available here. Would you suggest a stronger mixture than what the label might recommend?
At idle or maybe 1,000-1,200 RPM, how long would you think an LB9 would take until all the fuel in the rails and fuel lines has been used and the new fuel with the stabilizer has started going thru the injectors? I would think at least 20-30mins?
Old Aug 27, 2016 | 08:17 AM
TTOP350's Avatar
If you seafoam it, put that in 1st so the fuel will mix it up. The fuel is constantly being cycled through the rails and and back to the tank.
I'm by no means a fuel specialist so what worked for me (in controlled storage) may not work for everyone. I'm not saying the fuel was perfect after that long either but it got the car running and to the gas station.
Old Aug 27, 2016 | 09:14 AM
92GTA's Avatar
Ha, that's right it's a return system, I knew that too. I must be pretty dense today lol!
Old Aug 27, 2016 | 09:41 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Full fuel tanks prevent condensation.
Old Aug 27, 2016 | 11:26 PM
92GTA's Avatar
Well I can't fill my tank because it's not street legal to drive to a gas station. I will get at least 5 gallons in it though.
Old Aug 27, 2016 | 11:50 PM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
I just bought some Sta bil Marine 360 - gunna try it in my tanks for my cars are sitting as well.. Hoping the newer vapor stuff helps..
https://www.goldeagle.com/product/sta-bil-360-marine
Old Aug 28, 2016 | 07:08 AM
TTOP350's Avatar
No gas cans????
Old Aug 28, 2016 | 04:13 PM
92GTA's Avatar
Yeah a 5 gallon, just didn't want to make multiple trips to the gas station lol. Guess I should tho.
ULTM8Z
95
Oct 9, 2017 01:31 PM
StonersTA
Dec 3, 2016 09:13 AM
white88TA
Aug 10, 2016 09:35 PM
zimmstoy
May 10, 2016 10:45 PM
steven
Car Audio
Jan 27, 2001 06:45 PM
