CTSY FUSE
Old Sep 9, 2016 | 04:50 PM
mans1's Avatar
Car: pontiac firebird trans am 1984
Engine: 5.0 v8 H.O
Transmission: auto
Axle/Gears: 700R4 auto overdrive
CTSY FUSE
what does the CTSY fuse control on 84 trans am 5.0 V8 H.O as I'm having issues thanks
Old Sep 9, 2016 | 07:13 PM
Re: CTSY FUSE
CTSY = Courtesy Lights
It's all the relatively low-power constant battery things in the cabin. I.e. not power seats or things like that. Dome lights, cig lighter, radio station memory, ...
Whether it's the cause, would depend on the issues. And of course, whether it's blown.
Old Sep 10, 2016 | 09:22 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: CTSY FUSE
what happening is the dash lights are not working or the radio the headlights pop up but will not go down could it the CTSY fuse or something else
Old Sep 10, 2016 | 10:40 AM
Re: CTSY FUSE
Wouldn't have anything to do with dash lights or headlights AFAIK but those systems in the Firebird are unnecessarily complicated anyway and have too many parts, connections, etc. in them so I could easily be wrong. Might cause a radio problem.
Replace it with one of the same size from your spare fuse kit and see.
Old Sep 10, 2016 | 10:59 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: CTSY FUSE
what fuse runs them I did see a spark then nothing even the power door locks don't work now
Old Sep 10, 2016 | 12:34 PM
Re: CTSY FUSE
Old Sep 11, 2016 | 07:37 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: CTSY FUSE
hi I have got working the power locks the radio just a blown fuse but still not working are the tail lights and indicators and marker lights and the dash lights and gear selector light witch fuse is that the headlights go up and light up but not back down
Old Sep 11, 2016 | 07:56 AM
Re: CTSY FUSE
Tell us more about "spark".
Which fuse was blown that kept the radio and PL from working? Why did it blow?
Every single one of those light circuits you talk about, is DOWNSTREAM OF the headlight switch. They are all driven off of the tail light contact of that switch. EVERY ONE.
I'd be looking at the headlight switch if I was you, rather than fuses, for that one. Make sure it's plugged in, make sure 12V is reaching it, make sure 12V is going out to each destination, etc.
Old Sep 11, 2016 | 08:40 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: CTSY FUSE
problem solved it was another blown fuse everything is working now
Old Sep 11, 2016 | 09:40 AM
Re: CTSY FUSE
Glad to hear it.
And that other fuse was.... ??
Old Sep 11, 2016 | 03:09 PM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: CTSY FUSE
Glad to hear it.
it was the TAIL fuse
Old Sep 11, 2016 | 03:42 PM
Re: CTSY FUSE
Well that would make sense; would kinda explain why the whole TAIL circuit was out...
What about the first one?
What about "spark"?
Leave some info behind so that people in the future can benefit.
Old Sep 11, 2016 | 03:50 PM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: CTSY FUSE
What about "spark"?
the spark was a wire touching something it should not have done as it was a loose wire in both cases but sorted now I saw that is what blew the fuse in both cases not the same wire, now the dash lights, Tail and headlight now work and indicatiors and marker lights there on the TAIL fuse the radio and power locks are on the CTSY that's on my 84
FrankieRider2
Sep 15, 2016 05:14 AM
Hawkeye1980
Jun 23, 2016 02:27 PM
mitchberry
Aug 27, 2012 03:34 PM
G.I.JOEY
May 10, 2006 06:21 AM
86Z
Oct 12, 2004 01:49 PM
