is there a fuse
Old Sep 9, 2016 | 04:05 PM
mans1's Avatar
Car: pontiac firebird trans am 1984
Engine: 5.0 v8 H.O
Transmission: auto
Axle/Gears: 700R4 auto overdrive
is there a fuse
hi I have an issue the int lights I mean the cluster lights and centre console are not coming on when i put the park light on or the headlights on and they go up but not back down also the radio also doesn't work either now everything else seems to work ok is there a fuse for it it seems theres no power to the headlight motors them selfs
Old Sep 12, 2016 | 04:51 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light Plight
There is a fuse for the dash lights, it’s the INST LPS fuse.
It’s in a Fuse Block which is located up and to the left of the brake pedal, behind a small door.
If the fuse looks good, make sure the dash dimmer control is set at the bright position, the headlight switch in the marker lights position, then using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe BOTH sides of the INST LPS fuse.
If there is no power both sides check for power on the
orange wire at the headlight switch.
Then check for power on the
dark green wire at the headlight switch.
Is there power on both wires?
In that same fuse block you should find a 10 amp fuse for the radio.
Make sure it’s good.
For the headlight doors use a voltmeter or small bulb to see if there is power on the
White wire at the headlight module when you turn off the headlights.
Happy Racing !
Nitromethane Smells Sweet Burning, But Please, No Roasting Marshmallows On The Zoomies
Bobby Suth
Sep 9, 2016 06:46 AM
zs&tas
Sep 8, 2016 12:09 AM
jimbear56
Sep 7, 2016 06:07 PM
patricks85z28
Sep 5, 2016 10:51 PM
Hawkeye1980
Sep 5, 2016 01:28 PM
