What connector is this?
Old Dec 16, 2017 | 12:38 PM
shaynecastongua's Avatar
Car: 1985 Trans Am
Engine: Chevy 355
Transmission: T5 NWC
1985 Trans Am, the connector comes out below the steering column and appears to go up over the column on the left side. Anyone know what it is? Thanks!
Attached Thumbnails What connector is this?-20171216_131235_hdr.jpg   What connector is this?-20171216_131247.jpg
Old Dec 22, 2017 | 07:02 PM
Car: 1985 Trans Am
Engine: Chevy 355
Re: What connector is this?
Anyone?
Old Dec 22, 2017 | 09:02 PM
OrangeBird's Avatar
Car: 1989 Firebird
Originally Posted by shaynecastongua
Anyone?
Hi Shane ,
I'm not 100% certain , but , the colors on those wires look a lot like the listed wires for the cruise control on your wiring diagram (1985 T/A) .
I will enclose your wiring diagram , the detail you seek is at the bottom right hand side of the page (click twice on the image to see it in full size) .
Attached Thumbnails What connector is this?-fig21_1985_body_wiring_continued.gif
Old Dec 23, 2017 | 12:21 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
That's the cruise control connector. It comes in through the firewall with a vacuum line. The hole they come through is lateral to the accelerator cable and steering column. The interior side connector does indeed join up with the interior wire harness and go to an ecm. That ecm is connected up towards the windshield attached to the back of a duct. The cruise ecm is a small aluminum case. If you don't want or need cruise you can just leave it.
Old Dec 23, 2017 | 02:01 PM
Car: 1985 Trans Am
Engine: Chevy 355
Ok, I will just tuck it away somewhere, I don't need cruise control right now. Thanks guys.
Old Dec 23, 2017 | 02:05 PM
Tibo's Avatar
Car: 1991 Z28 Vert
If you don't want cruise then you could also use it to control something.... The cruise switches could just become an on/off switch for whatever.
kevosiroc
21
Dec 12, 2019 10:51 AM
87350IROC
Jul 31, 2010 08:26 PM
john5.7 87Iroc
Dec 1, 2004 04:34 PM
