85 Z28 Won’t Start After Installing Aftermarket Stereo
Old Jan 4, 2018 | 11:23 PM
CKalinowski's Avatar
I recently put in a new radio in my 85 Z28 and now it will not start. Prior to this it would start right up. Before installing the radio I took out the battery. I have put the battery back in the same way. It now just clicks when I turn the key. I tried jumping it but got the same result. Any idea what the problem might be???
Old Jan 5, 2018 | 08:49 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: 85 Z28 Won’t Start After Installing Aftermarket Stereo
Low voltage on the battery, or you don't have the terminals tight enough. There is no reason to remove/disconnect the battery for a radio install
Old Jan 6, 2018 | 02:59 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The Manufacturer's fear of lawsuits. Any instructions today always dictate you disconnect the battery, wear eye protection, remove the fuel pump fuse, remove the ignition coil wire, wear a respirator,
Old Jan 7, 2018 | 05:28 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
What manufacturer? I see a DIY guy disconnecting a battery for a radio install
Old Jan 8, 2018 | 02:41 AM
irocwagon's Avatar
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
Sounds like a loose cable or weak battery
Todd 92 Z
May 20, 2024 12:31 PM
Ghettobird52
Apr 12, 2014 02:20 PM
cjlac96
Dec 12, 2013 10:46 AM
camaro 22
Aug 1, 2013 04:41 PM
HuggerI-ROC
Dec 21, 2006 07:59 PM
