Toggle switch
Old Jan 15, 2018 | 11:03 PM
SketchyZed's Avatar
Car: 1991 camaro z28
Engine: 5.7
Toggle switch
What kind of toggle switch amps for radiator fan?
Old Jan 15, 2018 | 11:17 PM
SketchyZed's Avatar
Engine: 5.7
Re: Toggle switch
I'm gonna be doing a carb swap so i would like to know if this is the right why to set it up http://img.photobucket.com/albums/v3...al_relay-b.jpg I just didn't know what amp switch i would need
Old Jan 15, 2018 | 11:24 PM
Keaton's Avatar
Re: Toggle switch
Hello I'm new to thirdgen I'm trying to figure out how to make a new post. If anyone could let me know that'd be great.
-Keaton
Old Jan 15, 2018 | 11:28 PM
Keaton's Avatar
1982 Trans Am fuel pump problem 305 cfi
Hello everyone, I have a 1982 305 cross fire injection Trans Am and I have no power at my fuel pump. I am trying to figure out what my next move is. I want to check the fuel pump relay on the driverside firewall but I don't know which one it is. Any help would be apprieated.
-Keaton
Old Jan 16, 2018 | 07:05 AM
Re: Toggle switch
To operate a relay only takes a few milliamps of current. (thousandths of an amp) Practically any switch you can buy would be plenty.
Best way to wire it though, is NOT like that diagram. Instead, run a wire from Ignition in the fusebox or elsewhere, to one coil terminal (85 or 86), then hook the switch from the other coil terminal to ground. That way, you can put a temp switch in parallel with the manual one, so that the first time you forget to turn it on, you don't melt your motor.
There's better schematics around than that one, including several on this site.
Old Jan 16, 2018 | 07:36 AM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Re: Toggle switch
-Keaton
Just go to FORUMS then into TECH/GENERAL ENGINE,hit "New Thread" near the upper left. You can also run searches by just throwing "no power to fuel pump 1982 Firebird site:thirdgen.org" or "fuel pump troubleshooting site:thirdgen.org" or any combo of those in any search engine, just don't forget the site:thirdgen.org
Old Jan 16, 2018 | 09:43 AM
SketchyZed's Avatar
Engine: 5.7
Re: Toggle switch
Thank you 😁
Old Jan 16, 2018 | 11:40 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Toggle switch
As others have said don't wire directly to a switch that is basically a red neck fire starter.
Do something like the attached pic
Old Jan 16, 2018 | 11:52 AM
SketchyZed's Avatar
Engine: 5.7
Re: Toggle switch
So not like this?
sorry bad drawing
Old Jan 16, 2018 | 05:03 PM
Re: Toggle switch
No...
I would put the switch in the black wire, on the ground side of the relay coil.
Then you should also hook up a temp switch to the same terminal of the relay that the switch goes to. That way, whenever the temp reaches [whatever], the fan turns on, even if the human fails.
For that matter, if I was doing it, I wouldn't use a toggle switch at all. I'd use the automatic temperature-controlled switch only. Like the car came from the factory. Might even use the factory temp sw and factory relay.
What's wrong with the OE circuit in your car? Why not just fix it?
Old Jan 16, 2018 | 05:08 PM
SketchyZed's Avatar
Engine: 5.7
Re: Toggle switch
nothings wrong with im switching to carb don't i have to make a whole new wire for it all?
... i can use the old relay cant i
Old Jan 16, 2018 | 05:17 PM
Re: Toggle switch
Not that I know of... the relay should still be good, the wire from the batt to the relay will still work, the one from the relay to the fan will still work, it should still get ignition on one side of the coil, all you have to do is ground the other side (the green/white wire if memory serves), which if the fan switch is/will be still in the head, will still work just like it always did... no sense in cobbling together something nowhere near as reliable as the factory stuff when all of that is still there and working, not that that's SO reliable, but it's almost always better than homemade...
Old Jan 16, 2018 | 05:31 PM
SketchyZed's Avatar
Engine: 5.7
Re: Toggle switch
Oooh i get it now so i would just ground a toggle in my car connect it to the green/ white stripe wire and it will turn on, but what about fan no.2 also would it be a safe way to wire it?
Old Jan 16, 2018 | 05:41 PM
Re: Toggle switch
Not sure how that one is wired... no doubt it has its own relay, just wire the 2 coils together and let them both turn on at the same time. Or, use 2 different temp switches, like a 210° and a 230° or something, and make it a 2-step.
Old Jan 16, 2018 | 05:42 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Toggle switch
A switch to f of the original relay to ground will control them.
Old Jan 16, 2018 | 05:57 PM
SketchyZed's Avatar
Engine: 5.7
Re: Toggle switch
Okay and this should all work when i go to the carburetor
MoDiPhYd
Car Audio
Dec 25, 2001 12:12 AM
midnightblus10
Jul 19, 2001 09:21 AM
91RSconv
Apr 17, 2001 12:37 PM
