Tach reads to high after ECM replacement.
Old Mar 14, 2018 | 04:32 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
My tach was reading fine until I replaced my ECM, now it reads too high. Does ECM control voltage to the tach? What else could be wrong?
Old Mar 14, 2018 | 05:40 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tach reads to high after ECM replacement.
The tach feed is directly off the coil the ecm is unrelated.
Old Mar 14, 2018 | 05:42 PM
Engine: Lb9
Transmission: M20
There is a diy thread on the tach board fix 90-92 or you can get a new board.
https://www.thirdgen.org/forums/engi...achometer.html
https://www.thirdgen.org/forums/elec...meter-fix.html
Old Mar 14, 2018 | 07:19 PM
Thank you. I suppose a capacitor has failed.
Old Mar 14, 2018 | 08:51 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
You still have the V-6 tach or have you installed a new V-8 one?
Old Mar 15, 2018 | 09:26 AM
Can't tell. Cluster was a (140 mph) replacement from Canada. It worked til I replaced the ECM, but that's probably a co-incidence.
Old Mar 15, 2018 | 03:03 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Well, if it worked correctly before then it would be a V8 one. If it was the same one that worked when the V6 was in there then you would have a problem.
I don't even know if there ever was a 145 mph V6 cluster. As long as your oil pressure gauge goes up to 60 lbs and not 80 lbs it should be a V8 cluster
jmk1938
Jun 26, 2017 05:04 PM
slayernut
Apr 27, 2010 03:21 PM
5.0 Eater
Mar 9, 2010 08:52 AM
purg3d
Mar 9, 2008 05:14 PM
xplane
Oct 9, 2007 04:36 PM
