Dome light not working iroc
Old Jul 13, 2018 | 10:32 PM
Thunderhead's Avatar
Car: 1987 Iroc-Z
I have an 87 IROC t-top with the overhead console , Dome light isn't workinghowever cig lighter, mirrors, ect all work...?
Old Jul 14, 2018 | 08:21 AM
Re: Dome light not working iroc
Bulb?
Old Jul 14, 2018 | 03:23 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
IIRC that bulb connection should have constant power via an orange wire and it grounds out when the doors open via the door switch. Check to see if you have power at the orange wire and with the door open a ground at the white wire.
If you have power and no ground you can try unplugging the door ajar sensor and just grounding it to some metal.
89305GTA
Sep 28, 2017 05:01 AM
85Iroc-Z
May 1, 2014 10:09 AM
smeds
Jul 1, 2013 05:41 PM
TransAmman87
Mar 24, 2007 08:28 PM
TekViper
Feb 2, 2003 03:35 PM
