Window wiper will not shut off
Old Jul 23, 2018 | 06:36 PM
Purplecamaro92's Avatar
Car: 1992 camaro RS
I'm picking up a 1992 RS on Friday, when i took it for a test drive the window wiper would turned on no problem but would not turn off until i turned off the car and rested it then it was off. Has anyone else had this problem and would getting a new turn signal switch solve the problem or what would it be? Thanks
Old Jul 23, 2018 | 06:40 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Window wiper will not shut off
Most likely the Park switch inside the wiper motor assembly,... or the motor assembly itself. ( doubt this is a lever/switch problem ) You might be able to find a replacement wiper motor - but it might be difficult to find a replacement Wiper Motor COVER. There is a very specific way that the Cover must be installed or it will get damaged........ keep that in mind !
Old Jul 23, 2018 | 07:49 PM
NoEmissions84TA's Avatar
I had that happen to my truck.
Water/moisture managed to get into the wiper motor cover/circuit board.
And wouldn't you know - it happens ....... when it is raining.
Old Jul 30, 2018 | 04:53 PM
Car: 1992 camaro RS
thank you both i will look for a new motor and go from there!
Old Aug 5, 2018 | 05:56 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
How's your search going? I was at the local wrecking yard and spotted a pretty clean 90 TBI equipped Camaro . Wiper motor and cover were still there.
I could possibly get them in the future if you are still needing any of those parts.
LMK, Henry
ziggy56
Nov 7, 2018 11:18 AM
TheGoatchrist
Mar 20, 2013 03:32 PM
bbsr72
May 4, 2008 09:38 PM
