can i use a 1991 4 pin alternator in my 1986 trans am with a two pin connection ?
Old Aug 24, 2018 | 04:53 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
my current alternator is bad and needs to be swapped out.the car is a 1986 trans am and it currently has the 2 pin white connector style alternator.
i recently bought a 1991 LB9 305 as a spare engine and it has a brand new 4 pin style alternator with it.( tag reads: wilson 90-01-4631 12v 2945 54 )
i was wondering if i can use the newer alternator and what do i need to hook up/change.i dont want to just wing it and overload my charging system.
i have this b/n alternator and not much extra money so this is why im trying to swap them.any help would be greatly appreciated,thank you.
the simpler the explanation the better
Old Aug 24, 2018 | 05:04 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: can i use a 1991 4 pin alternator in my 1986 trans am with a two pin connection ?
I don’t think the cs alternator is a direct bolt in replacement for your si.
https://m.ebay.com/itm/Alternator-Co...ss!90011!US!-1
Old Aug 24, 2018 | 05:09 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
i took it out to my car and eyeballed it,the mounting points look the same other than the connector position is rotated about 30-35 degrees inward or clockwise
looking from the front of the car at the alternator(it currently has the passenger side mounting)
the adapter you linked seems like it would work(possibly/hopefully)
Old Aug 24, 2018 | 05:11 PM
Engine: Lb9
Transmission: M20
You can remove the case bolts and red lock the housing of the alternator.
Old Aug 24, 2018 | 05:12 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
good point,thanks.i guess i cant just use two spade connectors and put them over specific pins then?
Old Aug 24, 2018 | 05:31 PM
Engine: Lb9
Transmission: M20
Old Aug 24, 2018 | 06:35 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
so using these two examples,what wires from the two pin plug from the right diagram would i connect(and to what of the plis pins) to the four pins,sorry im not too electronically oriented and looking at both it is mildly confusing.
Old Aug 24, 2018 | 06:45 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
like #1 on the right diagram goes to what letter pin on the left diagram,same with #2.im probably under or over thinking it.
here are pics of my existing alternator and my new one
Old Aug 24, 2018 | 07:08 PM
Engine: Lb9
Transmission: M20
If you have a idiot light you need a resistor.
https://www.jegs.com/InstallationIns.../764-30707.pdf
terminal 2 from the si is bat power or hook to the large lug on the alternator.
terminal 1 is a ignition switch power.
Old Aug 25, 2018 | 11:35 AM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
i bought a pigtail ready to change it out,in the meantime i charged my battery for a day and a half.
i filed down the posts nice and clean as well as the terminals in the car,examined all the connections
and pulled the fuse for the amp(big *** wire that was there from a previous install)i hooked up the
battery and it fired right up.i just got back from a nice drive(in the rain F%$X...)and it started up fine so
that tells me the battery is good(also had it tested,results came back good)and the current alternator is
doing its job otherwise that 10-15 minute drive would've drained the battery fully.
so now i do have a plan if it happens again,thank you kindly for all your advice.
whoever had this car before went from side post connections to top post connections with a bolt?
its some mickey mouse macgiver nonsense that i will sort out in due time,thanks again sir....or madame
CamaroPaul
Aug 23, 2013 12:37 AM
Gumby
Jun 16, 2011 03:20 PM
Gumby
Jun 16, 2011 02:57 AM
five7kid
Sep 27, 2009 08:51 AM
