melting fuse
Old Jan 8, 2002 | 09:33 AM
mark-debs87T/A's Avatar
melting fuse
i have a 87 T/A with an l98 engine.
i replaced the fusible link at the battery with a inline fuse holder. now the fuse wire is getting hot and melting the fuse. this all stated when i bought the car and i thought it was because the other owner hot wired the fans to come on when you turn on the car. they hacked up the wiring for it so i went and bought a new harness. but im still having the same problem any help would be great.
mark
87 T/A
2001 firebird
2002 ws6 T/A
Old Jan 8, 2002 | 11:38 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Are the fans still wired to run with the ignition on ?
Old Jan 9, 2002 | 08:02 AM
no i went and bought a new wiring harness ext. for the fans, so they are wired like it came from the factory.
Old Jan 9, 2002 | 11:33 AM
mtccl's Avatar
What kind of inline fuse did you use? It needs to be a high amperage fusible linke, not just an inline fuse holder with a regular fuse.
Old Jan 10, 2002 | 09:07 AM
thank you i did not know that. I did use just a reg. inline fuse holder. can i get one from discount auto or do i need to goto the dealer for it?
mark
Old Jan 10, 2002 | 10:10 AM
mtccl's Avatar
You can get one from Discount Auto. My Suburban kept burning the one from my alternator to the battery so I used a piece of 14 gauge wire to connect it with no further problems. The lower gauge wire will do the same thing. It will burn thru before you have major damage. It's is a workaround and you need to be aware that any electrical problem or indication thereafter requires immediate shutdown and inspection. Not a good idea if others are going to be driving your car.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
wstephan96
Sep 25, 2015 04:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
