Which instrument cluster sending units do I need?
Old Dec 5, 2018 | 03:13 PM
Moonan55's Avatar
Car: 1985 Chevy Camaro Sport Coupe
Engine: Chevy 350 w/ Vortec heads
Transmission: 700R-4
Axle/Gears: Stock 2.73
Okay, so I decided I want to swap my 85 mph dummy lights cluster with an 110mph one off an 88 tbi. I heard in order for the coolant temp and oil pressure to work, you need to swap the oil/coolant sensors with sending units. I tried looking up which ones I need, and like 4 types came up. I couldnt find this anywhere on the site, and it seems all cars have different ones. I know I need sending units, and not ecm sensors, but does anyone know the exact parts I need? I have a 305 v8 1985 Camaro Sport coupe, with the VIN letter G with E4ME carb, if that matters. Any help is appreciated.
Old Dec 5, 2018 | 07:31 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Re: Which instrument cluster sending units do I need?
You need the sendor for the gauge style not the dummy lights
what i did i went and got sensor from an 86 camaro with gauges even tho my camaro was an 84
you need oil, water (side of block) and that's it
Old Dec 6, 2018 | 07:32 AM
DEADWOLF's Avatar
Car: 1990 Firebird Drag car build
Engine: 355 being rebuilt
Axle/Gears: 4.56 LDS
I would input the donor car year and engine in the search bar and use those sending units. Basically a sending unit is a device that changes resistance based on the pressure or temperature it sees. Match the sensor to the receiver is the key. If the gauge is looking for a 0-100 ohm load the sensor has to use that range.
Moonan55
Feb 18, 2022 08:05 PM
Chuck84TA
Jan 30, 2013 12:29 PM
DirtDawg57
Feb 17, 2010 08:07 PM
igotmailed
Oct 3, 2008 09:45 AM
v8_musclehead
Mar 31, 2008 11:02 PM
