Emergency Brake Light Staying on
Old Jan 8, 2002 | 03:07 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
My ebrake light is staying on. I took the tan wire off the ebrake switch...the light is still on. Does the tan wire ground to turn on the dash light or what? The tan wire has no current. The light will not turn off if I ground the tan wire. Can someone help? Might I have a short? Thanks! -Jerod
Old Jan 8, 2002 | 03:48 PM
88firebird305's Avatar
Have to ask before someone else does.
Are you sure the e brake is not engaged?
Other then that I am no help.
Old Jan 8, 2002 | 03:50 PM
JMatlock88's Avatar
Car: 1991 Formula
UM...yes, I'm sure.
Old Jan 10, 2002 | 12:30 AM
wuter's Avatar
maybe its not your e-brake, that light will come on if there is problem in the hydrolic system too. theres a wire that goes to the prop valve, unhook it and if it goes out you have a problem.
Old Jan 10, 2002 | 11:22 AM
JMatlock88's Avatar
Car: 1991 Formula
Ah ha! That's it! So the next question is what could the problem be with my brakes? Any help appreciated! -Jerod
Old Jan 10, 2002 | 12:51 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
One circuit has failed. Check ALL of your brakes, jack the car up, and step on the pedal, (this will require a friend......) have someone try to turn the tires, one at a time, (while they are off the ground) and see which brakes are NOT working. Then you can try and see why. Chances are, you have popped a brake line somewhere, and are losing fluid. (might be real easy to find with just a casual inspection)
Old Jan 10, 2002 | 07:52 PM
JMatlock88's Avatar
Car: 1991 Formula
I did the brake check! Turns out that I dont have any back brakes. No fluid leaks are present, and there is no bleed down as I hold the pedal. How do you reset the prop valve once everything checks out? I would bleed the lines, but I doubt there will be any line pressure at the back brakes. After a visual inspection, there doest appear to be anything wrong. Could it be a blockage in the line? A sticking wheel cylinder? I think I'll post this in the brake section also to see if I can get some answers there. Thanks...I'd like some further help if anyone has anything to add!
Old Jan 18, 2002 | 01:48 AM
86_Dan_Z28's Avatar
Car: 86 Z28
I had the same problem and it turned out to be a shorted wire on the circuit board on the back of the instrument cluster.
Old Jan 18, 2002 | 02:47 PM
JMatlock88's Avatar
Car: 1991 Formula
As it turns out, it was just air in the lines. It was the prop valve switch. I blead the brakes and the light went off. The funny thing was, I hadnt messed with the brakes when the light suddenly came on. That is why my first thougt was the ebrake switch malfunction... Anyway, problem solved. Thanks thirdgen.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Jae992
Aug 27, 2015 09:07 AM
smooth
Aug 18, 2015 06:34 PM
stalkier
Aug 13, 2015 12:59 PM
