Rear hatch inoperable
Old Mar 4, 2019 | 03:27 PM
jamesv's Avatar
Car: 1987 Chevrolet IROC-Z Camaro
Engine: LB9 > L98 5.7-liter V-8 TPI
Transmission: MD8 4-Speed Automatic MX0
Axle/Gears: GU5 3.23 G92
I recently purchased a 1987 Chevrolet Camaro that has an issue with the rear hatch being inoperable. I located the ACC 15 AMP fuse slot and found it to be empty. When I attempted to insert a fuse in the slot it sparked and blew the fuse. I need help or guidance in locating the source of the problem? Thank you all in advance. James
Old Mar 4, 2019 | 03:40 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Re: Rear hatch inoperable
See Post 4 & 5 in the thread below. It has the schematics for the Hatch Pull Down so you can trace your fault...
https://www.thirdgen.org/forums/elec...or-wiring.html
Old Mar 4, 2019 | 05:34 PM
jamesv's Avatar
Thanks Ed!
NowhereFast
Jan 14, 2014 10:34 AM
89FRMLA350
Jul 8, 2010 02:53 PM
RSpeed
Dec 4, 2001 03:10 AM
