Where does the high speed fan relay mount with a non-AC HVAC box?
Old Mar 30, 2019 | 06:10 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Thinking of pulling my AC box and installing a non-AC box for more room to work on engine.
1. Where does the fan high-speed relay get mounted with non-AC boxes? I don't see a provision on the box.
2. I have two boxes and they have different fan speed resistors. One is from a '85 Camaro and has 3 pins with 2 resistors. The other is from a ??? and has 4 pins with 3 resistors. Why the difference? I am guessing I want the 4 pin model to work with my 4-position fan switch in the HVAC head unit in dash.
Old Mar 30, 2019 | 08:45 PM
CorvairGeek's Avatar
Engine: LG4
Transmission: 700R4/4L60
Re: Where does the high speed fan relay mount with a non-AC HVAC box?
I've not seen a high fan relay in non-AC applications in this era. The non-AC fan is a lower amperage fan motor.
Old Mar 30, 2019 | 09:07 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
You will have to get creative for the relay mounting. The non-A/C cars didn't have the relay.
The 4 pin resistor allows the extra fan speed for the A/C equipped cars. If you want to retain all 4 speeds you will need to reuse it.
Old Mar 30, 2019 | 09:57 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I swapped the shorter cage over to my AC motor and everything seems to fit right.
Where are you guys buying the blower motor hose? That's the one part I'm missing.
Old Apr 1, 2019 | 06:07 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Knows About Hose
HomeDepot.
This is not a misprint, HomeDepot.
Happy Racing !
Funny Car Fun Fact:Funnys can twist the crank so far that sometimes cam lobes are ground offset from front to rear to re-phase the valve timing somewhere closer to synchronization with the pistons.
Old Apr 1, 2019 | 06:33 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Huh. Who would have guessed. I'll give it a try!
crazybird
Dec 11, 2013 03:23 PM
Bobby_80s
Jul 13, 2012 01:36 AM
Damien00677
Mid-West Region
Feb 20, 2012 11:16 AM
Stevolwevol
Jul 29, 2010 08:20 PM
aziroc
Jul 19, 2002 02:44 PM
