Firebird headlight module same as C5 Corvette?
Old Jun 5, 2019 | 10:42 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
From the GM Parts Direct website, 1989 Firebird headlight control module 16523917. Also fits 2001-2004 Corvette.
Is that true? I could pick a module off a Corvette in the junkyard?
Not sure this link will work but we'll give it a try,
https://www.gmpartsdirect.com/oem-pa...ItOGwtdjYtZ2Fz
Old Jun 6, 2019 | 01:10 AM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Re: Firebird headlight module same as C5 Corvette?
Leave it to GM to use an antiquated part on a newer model
In all seriousness, hopefully so! I’ve seen this part requested a few times here, so it might be a good thing. No clue about if it works though, waiting for other responses there. Is this part the same on all the years with the flip up headlights? Or will they interchange? Comes to mind I’ve heard different part numbers for different years, but I would suspect that headlight assemblies were mostly the same throughout. I know later models used a smaller headlight but mechanically I would think they were the same.
Old Jun 6, 2019 | 01:17 AM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Desire to know more intensifies.
Old Jun 6, 2019 | 07:36 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
A search on Ebay seems to suggest yes...
https://www.ebay.com/sch/i.html?_fro...23917&_sacat=0
Old Jan 10, 2020 | 10:54 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I found a wiring schematic for the C5 headlight module and compared it to a wiring schematic for my Firebird headlight module and the pinouts appear to be the same.
https://www.corvetteforum.com/forums...ht-module.html
Following the C5 trail I found that Eckler's Corvette sells replacement modules for $165. So then I searched the Eckler's Firebird catalog and found the Firebird module by a slightly different part number. This is the first time I've seen an aftermarket source for these puppies.
Old Jan 10, 2020 | 11:08 PM
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
That is good news ! I might need to grab a backup just in case.
Old Nov 8, 2020 | 08:14 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Just to bring this to a close, the Corvette module does work. Installed and operating in my '89 Firebird.
Post #1561, https://www.thirdgen.org/forums/ltx-...ml#post6402215
Old Nov 9, 2020 | 05:34 PM
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Excellent. Thanks for bumping the thread with the results !
LT1Formula
Exterior Parts Wanted
Sep 21, 2014 05:24 PM
jcurrieirocz
Jul 18, 2006 09:41 AM
Kwik89GTA
Aug 30, 2005 11:10 PM
joekickass
Jun 19, 2003 08:30 AM
TBI89Formula
Jul 30, 2002 06:34 AM
