No horn, No trunk button, No power antenna
Old Jun 16, 2019 | 02:27 PM
D Max's Avatar
Car: 1990 Pontiac Firebird 3.1 V6
Engine: 3.4 V6
Transmission: Automatic
Hello
Have some electrical problems lately....
Last week, I drove the car back home, with only 1 light up..
At the yearly technical inspection, I seems to have no horn, and it is a couple of months that I need to open the trunk with the key....
Could this all be related to 1 problem?
Today, I've been bizzy to the car...
Checked the fuses => all are good
Tested the horn relay => was ok
Put power directly to the antenna, => it worked
Put power directly to the truck relay => it opens...
Measured the headlamp door motors.... They all seem ok... Afterwards they worked again...
Seems like I get no power on the orange wire at the relay for the antenna, the radio gives 12v on the pink wire when it is on.
Same with the horn.... relay gets no power...
Somebody that can points me in the right direction?
grtz, D
Old Jun 19, 2019 | 04:04 PM
D Max's Avatar
Engine: 3.4 V6
Re: No horn, No trunk button, No power antenna
Little update...
Been buzzy today with it..
Dies anybody knows if there is a fusible link somewhere in the orange wire?
Like it is now, the trunk switch is not working, the antenna dies not come out and the Horn is not working...
I have no electrical schematic, so you following wires, I should cut it all up...
When I out 12v on the orange wire at the antenna Relay, zal works fijne
Grtz, D
Old Jun 20, 2019 | 09:35 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
FIRST...Check fuse #11 CTSY
Thats the fuse for those non workin accys.
Test for power there.
1-2-3-4
5-6-7-8
9-10-11-12
13-14-15
16-17
Old Jun 21, 2019 | 03:40 AM
D Max's Avatar
Engine: 3.4 V6
Are there other things that this fuse supply with power?
Old Jun 21, 2019 | 10:07 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
YES!
(on a 84 but yours should be the same)
#11 20 amp fuse powers
courtesy lamps, dome lamp, rear comp. lamp, clock, horn,
cig lighter, hatch release, power ant.
I would start there first with my test light!
csimpson1
Oct 6, 2009 01:34 PM
bbsr72
Aug 10, 2008 05:22 AM
Lime
Aug 31, 2005 09:15 PM
85berlinetta2.8
Jun 10, 2004 08:35 PM
