Found a strange plug in, what is it?
Old Apr 20, 2020 | 12:38 PM
Shaz's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 305 TBI
Axle/Gears: 3.08 non-posi
1987 Pontiac Firebird base 2.8 Automatic
Pulled a small twin pack of connections that were hiding behind the driver side foot kick panel (under the dash, right in front of the driver door jam) and out with them came this strange little one wire plug in. Is this some sort of diagnostic plug, or used to set the electronic timing on the primitive ECU, or what is it?
Strange plug in connector.
Old Apr 20, 2020 | 01:50 PM
Re: Found a strange plug in, what is it?
Somehow doesn't look factory but hard to tell from that photo. See if you can get one from closer up.
Old Apr 20, 2020 | 02:59 PM
Drew's Avatar
Looks about right to plug into the back of the fuse block. Could be an added circuit, could be factory, if it's not plugged in, it's probably for something your car didn't have. Some of the wiring for options is installed even if those options aren't purchased, it's just easier to make the harnesses somewhat flexible rather than custom building a harness just to add one more wire.
Shaz's Avatar
Engine: 305 TBI
Ask and ye shall receive!
Old Apr 20, 2020 | 03:53 PM
Drew's Avatar
I take back part of what I said, it's an inline connector or potentially intended to plug into the distribution block further up the kick panel/A-pillar, but I'll stick with it being for an option the car doesn't have. There's no marks to show the terminal was ever mated with the matching female terminal. The blade would at least be scuffed if it had, they're just tinned brass usually.
Old Apr 20, 2020 | 04:03 PM
Shaz's Avatar
Engine: 305 TBI
Good to know nothing is disconnected, but man my curiosity is killing me. I wish I knew what it would be/could be.
Old Apr 20, 2020 | 04:57 PM
Looks alot like what the cruise control cable in the steering column would plug into.
Old Apr 21, 2020 | 01:52 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Rear hatch unlock solenoid maybe,....... got a hatch button ??
VenomX-87
May 6, 2007 03:07 AM
84camaroZ
Oct 29, 2005 02:15 PM
SgtSkip
Jan 25, 2002 10:20 AM
QwkTrip
Pacific Northwest Region
Jan 7, 2002 06:58 PM
