Chilling Forecast
Old Jul 6, 2020 | 03:15 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Chilling Forecast
Just when you thot maybe the govt was correct when they told you R12 is evil and R134 is good, R134 will be banned for, yet again, a different refrigerant.
R1234yf.
R1234yf is flammable.
If your system springs a leak, hey you always thot flames might look good on your car.
A 16oz can of R134 costs about $7
A 16oz can of R1234yf costs about $90
So you might want to stock up on R134 now.
If you extrapolate, the next govt refrigerant choice will be at least $1,100 a can.
If you knew all of the above, that's good at least you didn't fall off you chair.
if a mod can move the above to Cooling..........
HappyRacing!
Front Wheel Drive Is For Tricycles
Old Jul 6, 2020 | 09:20 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Chilling Forecast
Why? ...
Old Jul 8, 2020 | 10:34 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
You can't make new devices that use R-134a but there's no ban on the manufacture or import of it. Keep using it.
Old Jul 10, 2020 | 09:46 PM
gw082008's Avatar
Car: 92 Firebird Convertible
Engine: 383 - First Fuel Injection TPI
Axle/Gears: 3:23
Take a look at R152a as replacement for R12.
rockett3s
Apr 11, 2013 08:29 AM
vantheman76
Mar 4, 2011 04:12 PM
Justinlf16
Mar 3, 2011 09:33 PM
DirtDawg57
Sep 1, 2010 01:13 PM
MikeT 88IROC350
Jul 15, 2010 07:12 PM
