Computer removal
Old Sep 16, 2020 | 02:47 PM
Limbhanger's Avatar
Car: 86 Z28
Engine: Stroker
Computer removal
What are you guys doing about the computer removal and associated pigtails? I am putting in a carb’d stroker. The 86 had the carb’d 305 with knock sensors, electric advance, all the stuff I don’t plan to use,
can I remove the computer without affecting other stuff? Speedo is mechanical.
I have been thinking about cutting the pigtails, taping them off and hiding it under convoluted tubing.
I still wish to use idiot lights for oil, temp, and fan. I will run gages for oil and temp as well. I plan to use the factory tach as well. I look at the schematics and see whats going where. I do appreciate any heads up.
Old Sep 16, 2020 | 02:50 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: Computer removal
Pretty sure the gauges are separate from the engine control harness, even on the fuel injected models.
Old Sep 16, 2020 | 02:59 PM
DON'T cut ANYTHING. Completely unnecessary to be a HACK.
The entire computer package is one giant harness; comes in from the right fender well. There's a thing that mounts on the side of the windshield cowl, about at the top of the pass side kick panel, that brings it through into the cabin and seals up the hole. On the inside, there's a kind of C or U shaped retainer, that slides off sideways, along the flat sheet metal; with that gone, the ENTIRE harness just lifts out. Then you can just spooge in a piece of sheet metal with some windshield butyl or something like that.
Put your harness, your ECM, your sensors and all the other parts you take off, in a box UNDAMAGED and UNMOESTED. Don't make your swap irreversible. You never know when you might need them. Who knows, might be like me, when I got a job in California, and had to put it all back on... which would have been IMPOSSIBLE if I hadn't done exactly what I just told you to do.
Old Sep 16, 2020 | 03:36 PM
Limbhanger's Avatar
Car: 86 Z28
Engine: Stroker
DON'T cut ANYTHING... Put your harness, your ECM, your sensors and all the other parts you take off, in a box UNDAMAGED and UNMOESTED. Don't make your swap irreversible. You never know when you might need them. Who knows, might be like me, when I got a job in California, and had to put it all back on... which would have been IMPOSSIBLE if I hadn't done exactly what I just told you to do.
O have thought about this. I did not realize the two were separate harnesses. Definitely the way to go. This car is a little hard to put it all back though. Thanks!
Old Sep 16, 2020 | 04:15 PM
OrangeBird's Avatar
Car: 1989 Firebird
......can I remove the computer without affecting other stuff?......
You didn't say if your car is manual shift or automatic , if it has an automatic transmission you will loose the torque converter lockup function without the ECM . There are workarounds for this , but I figured it deserved mention under the heading of "other stuff" ....
Old Sep 16, 2020 | 04:20 PM
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Very good point ^^^
Old Sep 16, 2020 | 04:25 PM
Limbhanger's Avatar
Car: 86 Z28
Engine: Stroker
I am doing a T56 swap from auto. I already had that one figured out before I asked. I appreciate the thoroughness.
Old Sep 16, 2020 | 04:26 PM
Limbhanger's Avatar
Car: 86 Z28
Engine: Stroker
I have the harness removed form the computer and the entire thing on the passenger side of the car. Just need to look at the GM shop manual to see where its might be tethered. Any insight would be great.
To clarify, on the kick panel side all is loose. On the engine side I removed the c-clip to strut tower. The harness moved maybe and inch. It fastened somewhere in the fender.
Old Sep 16, 2020 | 04:39 PM
I found this description somewhere on the Internet. Thought it might be helpful.
Take off the pass side hush panel; look at the ECM; follow the harness away from it; leads you right to it.
Old Sep 16, 2020 | 04:47 PM
Limbhanger's Avatar
Car: 86 Z28
Engine: Stroker
Its out. Thanks again.
1986camarojoe
Apr 5, 2003 02:49 PM
jfox55
Aug 12, 2002 10:08 PM
capn_crash84
May 25, 2002 12:12 PM
1991tealRSt-topGuy
Aug 2, 2001 08:46 AM
