Orange wire that looks like it should go to battery
Old Oct 28, 2020 | 10:17 PM
krewl2u's Avatar
Car: 86 Camaro Z28
I have a 1986 Camaro Z28 that was sitting for over a decade before i obtained it. I am in the process of getting it fired up from bad gas etc... From looking at a lot of videos it appears that the orange wire should of came out of the round splice on the positive end of the battery cable and on the other side it goes straight into the main wiring harness. On my end I just see a orange cut wire and didn't know what its function is.
Orange wire with connector near the battery and below the resevoir.
Old Oct 28, 2020 | 11:01 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: Orange wire that looks like it should go to battery
You are correct. It passes through a fuse and/or fusible link and into the positive battery cable.
Old Oct 29, 2020 | 12:16 AM
krewl2u's Avatar
Car: 86 Camaro Z28
TY for verifiying it.
Would you happen to know what it powers?
Old Oct 29, 2020 | 03:15 AM
Looks like the power lead for teh ECM.
Did this car suffer a EFI -> carb swap, or perhaps an "improvement" to the carb by switching to a non-computer-controlled one?
Old Oct 29, 2020 | 03:23 AM
krewl2u's Avatar
Car: 86 Camaro Z28
Seems stock to me. Quadra jet carbuerator with 305 motor. There was a wire that was half assed taped to positive side cable with butt connnectors on both ends that was connected to nothing so I assumed it must of gone to wire and battery at some point. Hopefully reconnecting it might help in getting this to run as I have only been able to keep it going with starter fluid.
Old Oct 29, 2020 | 08:54 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Similar Thread Might Help
https://www.thirdgen.org/forums/elec...connector.html
Old Oct 29, 2020 | 05:17 PM
krewl2u's Avatar
Car: 86 Camaro Z28
I reran the ECM line the way it was supposed to be and it ran obviously so much better. I ran the fuel line hose into a five gallon gas can straight to the mechanical fuel pump. The engine now runs solid besides the quadrajet constant clicking when it is powered up and not running yet.
Next will be pulling the fuel tank in replacing it due to age,gas guage doesn't work and the bad gas in it.
I appreciate your time and your expertise as I would still be wondering what that line affected.
Old Oct 29, 2020 | 06:56 PM
OrangeBird's Avatar
Car: 1989 Firebird
With the key on and the engine not running the clicking of the MCS (Mixture Control Solenoid) is totally normal .
Good Job on hooking the ECM's power back up , I'll bet it does run 1000 times better
Old Oct 29, 2020 | 07:28 PM
NoEmissions84TA's Avatar
Very smart using clean gas from a gas can.
Old Dec 15, 2024 | 08:26 PM
atony86iroc-z's Avatar
I know it’s an old thread by any chance were you able to find where it goes in the main harness , I’m thinking about connecting to the relay by the passenger side
Old Dec 15, 2024 | 08:56 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Post 4
Old Dec 15, 2024 | 08:59 PM
Post 4
post 4?
Old Dec 15, 2024 | 09:02 PM
Engine: Lb9
Transmission: M20
Originally Posted by atony86iroc-z
post 4?
yes ecm power/ fp
Old Dec 15, 2024 | 09:25 PM
yes ecm power/ fp
got it ! I can’t find where it goes in the harness I’m using a harness from a 305 trans am efi took the whole loom off to examine it but no luck of finding the wire in the harness the only wire that looks close to it was going to a relay by the passenger side fender . The car was sitting for 8 years rabbits and mice chewed up the harness and I found one from a trans am that was efi
Ghettobird52
Sep 12, 2017 07:44 PM
bigchief
Aug 28, 2006 12:30 AM
357tpirocz
Sep 16, 2005 08:31 AM
blk91z28
May 8, 2002 03:59 PM
